Go Back   Automotive Forums Car Chat > Mazda > Tribute
Old 04-03-2011, 12:11 PM
Caterer Caterer is offline
Exclamation 04 tribute LX (2WD, 3.0L V6) mechanical ??
Okay, the transmission kind of exploded in January, I had it rebuilt and while it was on the rack we noticed a decent amount of engine oil on the outside of the pan. Took it in to have the oil changed two weeks ago (at 149,845 miles) and I replaced the front brake pads and rotors the following day. That night the MIL came on, we pulled a P0420 (rear catalyst?) code at Autozone. It's been two weeks, still just the one code.
I'm noticing a smell of exhaust under the hood (and sometimes in the cab when sitting idle) as well as a slight hissing sound. The vehicle has a significant loss of power. It takes off fine, but it won't jack-rabbit. It won't exceed 3800 rpm's and obtaining a safe freeway speed of 60-70 takes much longer than it should. The Oil is also a bit lower than it should be (about a quart or so).
I'm wondering if there's:
A) An exhaust leak that's causing the hiss, the smell, and the code to be thrown.
B) A bad catalytic converter that's causing the performance issue and the code.
C) A gasket leak that's letting oil out and air in, causing the hiss, decrease in performance, and the code.
D) Some combination of the above.
Need to get this solved ASAP, any help would be GREATLY appreciated. Thanks.
Mark
Old 04-03-2011, 01:22 PM
adamgrant adamgrant is offline
Re: 04 tribute LX (2WD, 3.0L V6) mechanical ??
Sounds like the converter is plugged... that will give the poor performance and P0420. Smell could be a defective converter or just oil burning on the manifold from teh oil leak.
The Following User Says Thank You to adamgrant For This Useful Post:
Caterer (04-03-2011)
Old 04-03-2011, 01:51 PM
Thanks, planning on taking it in tomorrow. Not sure oil would produce an exhaust smell though.
Old 04-03-2011, 02:14 PM
danielsatur danielsatur is offline
A DTC P0420 is usually throw when a catalytic converter is blown, a plugged Cat
would cause Misfires, over heating, and could choke an engine out!
1) Have a muffler shop check your catalytic converter with a back pressure test, it's alot cheaper.
Because of Age + Mileage suspect bad plastic, rubber seals, and gaskets.
A smoke test can pin point vacuum leaks on your Intake, EGR, and PCV systems.
Old 04-04-2012, 03:17 PM
Wow, I've been away too long. The Cat on the back of the engine was bad. Morel like shattered internally. Replaced that and still had issues. Turned out the shattered debris moved down the line to a third (unmonitored) Cat and plugged it up. Removed that one tried to drive it. MY OH MY what a difference. Too loud to leave it that way, so cleared the cat, reinstalled, worked just fine.
Old 04-06-2012, 12:31 PM
You might consider using a H02 cheater down stream to suppress the P0420's until a new catalytic converter.
96 windstar 3.0L tramission problem Steve45ca Windstar 3 01-17-2010 05:56 PM
89 Voyager Valve Train 3.0L Nate1169 Caravan | Voyager 0 09-12-2009 02:11 AM
How much is a 95 3.0L Voyager With 95k & Bad Tranny Worth? LightShifter Caravan | Voyager 2 05-30-2009 10:19 PM
99 GTV6 3.0L Overheating! Mechanics stumped! gvimercati GTV 0 12-15-2006 08:24 PM
If i dyno'd my car how much rwhp am i looking at? (STOCK 3.8L V6) TMC2k1 Camaro Discussions 26 07-04-2006 04:33 AM
Tags
catalytic , engine , exhaust , leak , oil
