Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > 1969 - 1994 Full size
Old 04-03-2011, 12:30 AM
Ranger75th Ranger75th is offline
87 Blazer won't start after new fuel pump
I installed a new fuel pump and tank. First try it fired right up. The next day, it would not start at all. Not getting fuel out of injectors, but getting fuel up to the throttle body.
5.7 liter 350
Old 05-22-2012, 08:20 AM
wallerus wallerus is offline
Re: 87 Blazer won't start after new fuel pump
Find a noid light (injector tester light), should be able to get one fairly cheap or make one. Pull injector plug and insert light. Have someone crank the engine while observing the light. If the light flashes then the problem is in the system before the injector (pump, filter , or regulator). If light does not flash it is in the computer side of the system (wirering, computer, solenoids, key switch, etc).
Old 07-24-2012, 11:42 PM
mhowe1182 mhowe1182 is offline
Im having the same problem but im not getting gas to the carb, i have put new pump,filter,injectors, press reg, pump relay, new connecting wires for the injectors.
1999 k1500 350 hd tranny
8 inch lift
35" tires
93 Jimmy won't start after replacing fuel pump GrStead123 Problem Diagnosis 2 01-13-2010 07:21 PM
90 cherokee won't start after replaceing fuel pump derricka01 Cherokee 1 09-20-2009 07:42 PM
1990 Honda Accord won't start after replacing fuel pump bborchers Accord/TSX/Accord Hybrid 3 10-04-2008 10:42 PM
88 TBI tail lights and remote start don't work after new fuel pump onetime_77 C/K 8 08-23-2006 10:32 AM
won't start after new fuel pump installation susansbostons Silverado 5 09-29-2004 06:56 PM
