Old 04-03-2011, 12:22 AM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Transmission Noise
Hey guys,
Ever since I purchased my use '90 C1500, there has been this loud ball-bearing type noise coming from under the car. Since the truck was pretty rusty, I assumed the noise was coming from the rear drums sticking (also the car felt like something was holding it back).
After servicing the drums to find out everything is fine, I find out that the noise is actually coming from the trans.
Here are the symptoms:
1) Loud ball bearing-type noise that increases with speed (almost sounds like a water pump bearing that has worn out)
2) Drag at high speeds (truck doesn't coast well/loses speed)
Any ideas what the isue could be?
thanks ,
alex
EDiT: should be noted that I changed the trans fluid/ filter to no avail, also seems to shift fine, if a slight bit hard
Old 04-03-2011, 11:46 AM
Schurkey Schurkey is offline
Re: Transmission Noise
Consider also checking the U-joints on the driveshaft; and the pinion bearing (is the pinion loose in the housing?) in the rear axle. Sounds can travel up 'n' down the driveshaft and appear to be coming from somewhere else.
COUNT the shifts from a dead stop with the lever in OD, and accelerating very gently. 1>2, 2>3, 3>4 + torque converter clutch (TCC)--four "bumps" where the RPM drops, although the TCC "bump" may be very mild. First Guess: You aren't in overdrive. Verify by driving at steady 50+ mph and moving lever to "3" and hearing the engine RPM go up. Verify TCC by driving steady 50+ mph, and lightly touch the brake pedal with left foot while holding gas pedal STEADY (not hard enough to apply the brakes, but hard enough to activate the brake light switch) TCC should disengage briefly, RPM goes up.
What color was the fluid, and how much/what kind of debris was in the pan?
That might contra-indicate not having OD. Is the throttle valve (TV) cable adjusted properly? LOTS and LOTS of TV cable and/or TV valve problems with those transmissions.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-03-2011, 11:57 AM
Thanks for the reply! My trans doesn't have overdrive, I think its a Turbo 400 3-speed.
When I changed the trans fluid, it was reddish brownish, very blood-like and not translucent at all. There wasn't a ton of debris, just the usual fine black metal powder, no big pieces or shavings. The rear diff fluid when I changed it yesterday was dark black and disgusting.
Old 04-03-2011, 01:32 PM
j cAT j cAT is offline
the transmission tail shaft bushing may be worn ..when checking the driveshafts/U joints with wheels off the ground rotate the drive shafts and check for wear ..the 400 3speed transmission is a very strong performer.
Old 04-03-2011, 02:33 PM
Thanks for the advice, I'm thinking this problem is probably a combo of the bushing and worn U-joints (read somewhere that vibration during accel/decel, which i have, may be cause by worn u-joints).
I'll go ahead and check on her and let you guys know!
Old 04-03-2011, 05:03 PM
I think it's unlikely that a C1500 would have a TH400; but what do I know? I'd love to see a photo of the pan. Does the dash indicator have an OD position?
Yup. That's the way axle grease is. Smells terrible, too...right?
Old 04-04-2011, 01:50 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If you have a two-piece driveshaft (for extended cabs and/or long bed), the center support bearing could be bad. It sounds exactly as you describe, coming from under the floor. A competent place can replace it for ~$125. It has to be pressed on and off.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-05-2011, 10:38 AM
Well I guess technically the tranny is a 3L80? It's got no overdrive (no dash indicator OD). It is a long bed standard cab, is there a way I can tell if it's two piece? It has a composite sheath along the length of the shaft.
Old 04-05-2011, 12:31 PM
jdmccright's Avatar
The RustBuster
You'll see a u-joint somewhere around where the bed begins and a half-circle shaped rubber isolator next to it. The carrier bearing is inside the rubber. It may be possible to remove the two bolts holding the bearing to the crossmember and push it up high enough to clear the crossmember so you can spin test it...the driveshaft yoke will slide out of the transmission tail to accommodate this.
If the bearing sounds like an old roller skate, it's bad. It should be quiet and have no play whatsoever.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 04-05-2011, 06:36 PM
Thanks I'll test this, it definitely sounds like an old roller skate (a LOUD old rollerskate) while driving.
So what is the exact name of this part that I would need to replace?
Thanks,
Alex
Old 04-05-2011, 07:03 PM
jdmccright's Avatar
The RustBuster
It's called the carrier bearing or center support bearing. You can buy it separate of the rubber, but it's usually more cost effective to buy it and the isolator together. Considering the age of the truck, the rubber is likely to be old and soft anyways.
If you remove the shaft to have it replaced, mark the crossbeam so you can center the bearing assembly to realign the shaft when you install it.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 04-06-2011, 11:25 AM
Just checked and its a 1-piece driveshaft, no carrier bearing. The transmission tailshaft is about 8" long though, my money is on the tailshaft bushing that j_cat mentioned, what do you think?
Old 04-06-2011, 03:49 PM
jdmccright's Avatar
The RustBuster
That or the u-joints. Raise the rear wheels and spin the driveshaft while your underneath the truck. You should be able to hear where the sound is coming from.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 05-21-2011, 09:47 AM
Finally got the chance to change out the u-joints. The rear one was fine, the front was worn and had some brinelling on two of the posts. Unfortunately the sound hasn't gone away! I'm going to try and raise the rear again to pinpoint this noise. BTW I noticed something strange when I took off the driveshaft. The transmission spline shaft was wobbly. Is it supposed to be like that or is that a major problem?
Thanks,
alex
Old 05-21-2011, 01:45 PM
Thanks,
alex
read posting #4 again !
Engine noise and vibration jpar1983 Intrigue 10 12-28-2010 07:33 AM
90 GC front end noise Selec-trak benjaminbunny Grand Cherokee | Grand Cherokee SRT8 1 12-20-2009 06:00 AM
Help! 94 2jz 6spd...transmission noise warman724 General 1 11-29-2009 09:21 AM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
Transmission noise ky_infiniti2000 Maintenance 0 10-09-2001 10:48 AM
