Go Back   Automotive Forums Car Chat > MG > MGB
Old 04-02-2011, 10:14 PM
jmrucker jmrucker is offline
cat converter getting red hot
1977 mgb, I started it for the first time this year and it seemed to be chugging and blowing black smoke out the tail pipe. I checked under the hood and the cat converter was cherry . so i shut it off right away. any ideas of what it could be? i'm guessing a plugged converter?
Old 04-03-2011, 07:21 AM
snshddog snshddog is offline
Re: cat converter getting red hot
I would check for a cylinder that is not firing. That would push unburnt fuel into the exhaust which would explain black smoke and a overheating cat. A plugged cat should not make the black smoke. Could be a stuck float in the carb causing overfueling. There other possabilities but I would start there.
Old 04-03-2011, 05:07 PM
thanks for the help i'll start there, it just might be the carb i have never rebuilt it and it has sat a long time i ran it last year when i started to work on it but it sat all winter thanks again.
Old 07-03-2011, 05:42 PM
thepeggasus thepeggasus is offline
Another possibility are the screws securing the automatic choke assembly to the carburetor. They can back out over time thus allowing the mixture to richen. This can also cause a fuel leak leading to a fire so this should be checked in any case.
Old 07-30-2011, 10:06 PM
danielsatur danielsatur is offline
Also check similar threads @ the bottom of yours.
1995 Cirrus, Catalytic converter gets red hot pappaneil Cirrus 0 02-29-2008 12:05 AM
Exhaust Manifold gets RED HOT!!! Texan4ever Commercial Trucks 3 04-17-2006 02:26 AM
CAT CONV glowing red hot/ engine rough idle/rough ride F-BRD_fan Camaro Discussions 4 03-01-2006 04:12 AM
timing 42 degrees retarded exhaust gets red hot dirtdog4u Blazer 3 10-29-2005 05:21 AM
my 4runners manifold is getting red hot runner4 4Runner/GX470 0 01-20-2004 05:28 PM
