Old 10-28-2005, 10:46 PM
dirtdog4u dirtdog4u is offline
Question timing 42 degrees retarded exhaust gets red hot
have 96 blazer with 130k starts fine and runs great till it gets warm then it is real sluggish when you step on the gas (no power) then i noticed
the longer it runs the exhaust pipe starts glowin red on passenger side right out of the manifold took to a garage put tester on it showin retarded 42 degrees please cause of problem and solution if anyone has any idea's thank you
Old 10-29-2005, 12:54 AM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: timing 42 degrees retarded exhaust gets red hot
Are you sure it's retarded 42 degrees? That's awfully late. Did you/they reset the initial timing back to specification?
Mark's Garage est. 1983
Old 10-29-2005, 01:01 AM
drdd's Avatar
drdd drdd is offline
so, the header is glowing red?
OR
the exhaust pipe BEFORE the catalytic converter is glowing red?
yes? or, is it the exhaust pipes AFTER the catalytic converter glowing red?
ever had a new fuel filter? new catalytic converter? ANY CODES? have you done any tune-up items lately?
has the distributor been out, changed, or messed-with lately /
Old 10-29-2005, 05:21 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Most common reason for a glowing red exaust is a blocked cat... The ecm may be leaning out the engine too much because of that blockage...
