Old 04-02-2011, 09:09 AM
Scottm69s Scottm69s is offline
2002 Cavalier 2.2 Low Coolant Light
I have a 2002 Cavalier 2.2l 4cy. stick shift. Yesterday i changed the thermostat, filled the coolant and it started running hot and the Low Coolant Light turned on. I purchased another thermostat and replaced it. Then I found the bleeder screw and could not get any fluid to come up. The engine was still running at about 195 degrees and the low coolant light was still on. I then purchased the sensor for inside the coolant tank and replaced it. Turned the bleeder screw until fluid came out this time. Still having the same problem with the Low Coolant Light. Its hard to see the level of fluid on the side of the tank but it looks close to the cold line. Does anyone know what i should do next?
1997 Chevy S10 2.2 Starts Then Dies Logan76 S-10 9 07-29-2010 03:44 PM
2000 Ford Taurus w/ Low Coolant Light ON dumb2cars Taurus | Taurus Wagon 3 02-21-2010 08:39 PM
Check Coolant Light lance_kidd Grand Prix 12 10-12-2009 01:23 PM
no start 95 cavalier 2.2 jeffyweasel Cavalier Problem Diagnosis 2 03-14-2009 06:12 PM
Low-Coolant Light on 2000 Cavalier when I shift from 3rd to 4th Gear only. sreddy17 Cavalier Problem Diagnosis 1 09-15-2006 12:47 PM
