Old 04-01-2011, 08:35 PM
KairoCross KairoCross is offline
DIC not working
The DIC does not light up at all, the TCS off light is
on and the button doesnt work, if i pull the DIC fuse
the TCS works again.
Any suggestions?
Old 04-01-2011, 11:58 PM
ChaseMark ChaseMark is offline
Re: DIC not working
I think you may need a code for it right? You might have to get a dealer to program it for you. It's probably the easiest way. May cost you though.
Old 04-02-2011, 01:41 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: DIC not working
What year and mileage do you have. Are you having any other problems? Like your blower not working on certain settings. If this is not your DIC directly, your ignition switch could be on the way out. This is common on these cars. My DIC was dimming on one side last year and I just replaced the bulbs but this sounds more than just your back light bulbs burning out. There is no code or reason for a dealership to program our DIC's.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 04-03-2011, 02:29 PM
Re: DIC not working
2002 with 232000 KM
Ive basiclly been replacing alot of things, But so far my fan
will not work on 5, the 3 buttons to the left of the DIC are
not lit until i have had the car running for about 20 minutes,
they light up after, but when i slow down and come to a stop
they turn off, also my heated seat doesnt seem to want to
turn off so i had to pull the fuse.
On a side note, my TCS dont work but the TCS button
lights up, i pulled the DIC fuse to see what would happen and that
made my TCS work again.
Old 04-03-2011, 02:40 PM
Re: DIC not working
A Flaky ignition switch can and will cause all kinds of electrical problems, including your symptoms. There's a step by step instruction guide in our "Tips and Maintenance" section to replace it. And you can run a search here to find others who have had the same problem.
4 door sedan
No Mods
Old 04-03-2011, 02:46 PM
Re: DIC not working
I have already did the research on replacing the ignition switch,
Just trying to find the cheapest method of getting one
DIC not working kpabt0525 Grand Prix 1 02-01-2011 11:21 AM
97 Breaks not working crackedvenom Taurus | Taurus Wagon 1 05-12-2010 08:17 PM
DIC not working properly, a few other things AspenSTi Grand Prix 2 12-07-2009 04:15 PM
DIC gas gauge,speedometer, temp gauges not working hotep Aurora 7 05-09-2005 10:26 AM
