Old 03-31-2011, 10:33 PM
captain1230 captain1230 is offline
Possible Transmission Slip
Well I cant figure this problem out on my own. The car is running fine and I can get it to go as fast as I want with no problems. The issue I have though is that at speeds above 45 or 50 when I maintain speed the RPMs will sometimes drop slightly causing the car to shake. There are no problems until I hit this speed. If i let go of the gas and hit it again the problem goes away or if i accelerate and give it gas it also quits shaking. It does this continually as I drive at or above these ranges. Any idea what it could be?
Old 04-01-2011, 10:29 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Possible Transmission Slip
sounds like a torque converter lock-up solenoid going bad, as that is the threshold speed at which it engages.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-01-2011, 09:34 PM
trannyman52 trannyman52 is offline
sounds like a converter locking,,,un-locking,,,,,can be caused by tcc valve not working correctly....valve has issues with side loading causing it not to seat in lock position... Sonnax after market parts resolve this problem,,,but this repair is not a back yard job.
You may want to talk to a trans shop,,,requires valve body removal,,some shops don't want to deal with this type of repair liability
1995 Astro Transmission Slipping Dannoastro M Bodies 5 02-12-2011 12:07 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
NEED HELP!!! Dodge Ram Slipping Transmission jon2dope1987 Ram Pickup | Ram SRT10 2 09-04-2009 01:58 AM
99 civic w/ slipping problems. related to intake? melty '96-'00 Civic 0 07-23-2009 03:17 PM
New Transmission Fluid cause slippage DallasMEF Explorer | Explorer Sport Trac 3 06-15-2009 08:30 PM
