Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 03-28-2011, 03:53 PM
Apseubert Apseubert is offline
Electrical issues
Hey,
I'm new to the forum so bear with me please! I recently replaced the clutch position switch and ignition switch on my 02' Hyundai Elantra GT. When I put everything back together I found that several of my electronics (which previously work fine) no longer work, such as my gas gauge shows random readings and the gas light comes on and off periodically regardless of how much fuel is in the car, the interior lights won't come on anymore, the stereo is out, the dash board clock, and the electronic door locks don't work unless the key is in the on position. Before you ask, yes, I checked every fuse in my car, both under the steering wheel and out in the fuse relay box out by the battery. I checked the back of my stereo with my volt meter and found that it WAS getting power through the red wire, but the yellow(accessory) wire was not getting anything at all... Any thoughts or suggestions would be greatly appreciated. I just really don't want to tear my entire car apart trying to find where this is coming from. Thanks in advance!
01 Jimmy 4WD Strange Electrical Issue chobes Problem Diagnosis 3 12-29-2010 11:55 AM
New electrical issue Malacite69 Cavalier Problem Diagnosis 0 03-09-2010 02:33 PM
2001 ZR2 electrical issue airboss20 Problem Diagnosis 4 12-26-2009 07:59 PM
1998 Passat Electrical Issues mns247365 '97+ 2 05-22-2009 12:36 PM
2001 cav electrical issues Raeven Cavalier Problem Diagnosis 0 04-29-2009 09:23 AM
