| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
97 Eclipse RS
No Mods Automatic Transmission Smokes white sometimes but dont think its related. No Codes No Check Engine Light On Replaced All sensors on top side of motor cleaned throttle body replaced wires plugs and coil pack replaced the valve idle air control my next guess is the speed control sensor but no problems with the speedometer...??? Car will stall sometimes in park or drive while at traffic lights or driveway. Car will stall out while accellerating and check engine light will blink 1 time with stall, but then jerk back and continue to run AUTOMATIC TRANSMISSION. this is not an all the time problem When car is not stalling which is 95% of the time it runs perfect with a slight puff of white smoke every now and again because of a small oil burning issue in motor which i believe is unrelated.. but has caused some of the sensors to get a little dirty. PLEASE THIS IS MY WIFES CAR AND WE CANNOT AFFORD TO KEEP REPLACING THIS AND THAT IE SENSORS THAT ARENT FIXING PROBLEM. Friend wants to put on a scanner and monitor real time but that wont be for a few weeks. THANKS |
Re: 97 Eclipse RS Dies Sometimes At Idle And Sometimes While Accellerating But Keeps Running
Did you replace the PCV valve? Sounds like the same symptoms I faced once with my Firebird and that's what the problem was.
-Brian
Could the computer be doing that?
![]() 1995 Eclipse RS 5psi Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust. |
yes i have replaced pcv no change
I wish some of the 420a motor guys would chime in here. I don't really know as much about that motor as I should... Other things to consider checking would be vacuum leaks, dry rotted seals such as injector seals... Have you tried another MAF sensor to eliminate that being the problem? I'm just throwing a few extra things out there since you covered all the basic checks already.
-Brian
