Old 03-26-2011, 08:34 PM
ipjkcu ipjkcu is offline
eating oil & running rough when warm???
so i have 95 1 liter 5 speed, it runs fine and smooth first thing, but once it gets warm it idles rough, poor mpg 33-37 and eats a lot of oil have to say a quart every 300 miles does not leak oil, does not smoke, need new muff and resonater. check engine light is not on. can i hook it up to hand held code reader .? 95 is it obd 2?
plaese and thank you all for your help g/f drives car 50 mile one way to work so i need to figure it out. lol
Old 03-27-2011, 04:20 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: eating oil & running rough when warm???
No code reader, it's OBD1 and the code reader is built in. Put a fuse in the extra, raised slot in the fusebox, it will signal error codes by blinking the CEL. Chances are, you have none stored though, they usually will light the CEL to alert you.
It's probably just wore out, get a compression test, all plugs out, engine warm, throttle wide open. Factory sped is 200, 150 is "minimum allowable", they'll usually run 'til they get down around 100.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 03-28-2011, 08:16 PM
so i think my check eng ligt does not work. it does not come on when you trun the key to first start i have never seen it flash or blink any body help me does it come on when you turn the key to the run postion???
Old 03-29-2011, 03:44 AM
Rooy Rooy is offline
Yes it should come on by turning the key to run. Sounds like it's burnt out.
92 Legacy runs rough when warmed up. diggler1971 Legacy / Liberty / Baja 4 02-28-2009 10:51 AM
93 1.8 ltr runs rough when warmed up trox Escort 3 01-21-2008 08:54 AM
Runs rough when warm, at low RPM's bobrocken Cressida 0 12-21-2005 11:50 AM
93 runs rough when warm joellthomas Prelude 4 02-15-2005 07:11 PM
vortech runs rough when warm Joequin Blazer 15 12-06-2004 03:52 PM
