Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-01-2005, 07:19 PM
joellthomas joellthomas is offline
93 runs rough when warm
My 93 (auto) runs smooth and strong after first started and the engine is cold. When the temp gets to 1/4 it starts to run rough when the throttle is opened to accelerate. When the temp gets to 1/2 (normal) it will hardly accererate and shutters bad as the throttle is opened. Runs ok while running at a steady speed. Checked fire at each plug- OK, replaced fuel filter- No Help, Don't see any vacuum hoes off.
help!!
Old 02-06-2005, 08:22 PM
Re: 93 runs rough when warm
wus a plug wire, started missing at idle.
Old 02-06-2005, 10:31 PM
hontoy's Avatar
hontoy hontoy is offline
Banned
help!!
sounds like your ecu is trying to lean out your air/fuel mixture when engine gets warmed up. check your engine coolant temperature sensor. signal voltages should be around 1 volt when engine is warmed up or in closed loop.
Old 02-07-2005, 07:39 PM
OonePrelude OonePrelude is offline
Is your check engine light on? I had this exact same problem a little while ago. It turned out to be the MAP sensor. It was going bad. Easy to replace and is only ~$75.
2001 Honda Prelude DOHC VTEC
AEM CAI
Custom exhaust w/ Fireball Muffler
Old 02-15-2005, 07:11 PM
thanks for replying. It actually turned out to be a simpler fix. a plug wire was jumping over down at the plug. it finally started doing it all the time so even i could find it. replaced the wires, dist. cap and rotor. boy was that rotor hard to get off, had to use a puller.
