Old 03-26-2011, 10:59 AM
glc4123 glc4123 is offline
1997 pontiac grand prix brake caliper ABS
yes, i want to replace the caliper on driver side of my gp. do i have bleed all the wheels after installation or only the driver side?
Old 03-26-2011, 11:24 AM
inafogg inafogg is offline
Re: 1997 pontiac grand prix brake caliper ABS
are you just replacing the L/F caliper then just bleed the 1 wheel
but calipers are usually done in pairs
why just the 1?? most will tell you to bleed all wheels, to bleed some of the
old,dirty br/fluid out any time you open the system,this is good to do
brake fluid should be changed every 2 years,so if it has'nt been done
it would be good to do it now.THIS keeps the dirt out of the ABS system
the rear calipers on your car have been a problem since they started
using them(e-brake sieze)which is part of the caliper
so what are you replacing the caliper for???siezed/leak
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 03-26-2011, 12:07 PM
thanks for the reply, the one caliper is sticking not retracting all the way, and it makes a lound noise when the brakes are pushed,sounds like thump noise.
Old 03-26-2011, 12:47 PM
ok sounds like the rotor is warped(thump,thump)it will need to be
resurfaced or replaced,good time to replace pads also
Live For Today
Yesterday is gone,
Old 03-26-2011, 01:22 PM
thanks again for the help, i repaced new pads and rotors not long ago, as i mentioned when you hit brakes at low speeds you can hear a loud noise,only at low speeds. all help would be appreciated.
Old 03-26-2011, 01:44 PM
do you hear the noise(thump)just one time or is it more of a thump,thump,thump
when brakes are applied??
Live For Today
Yesterday is gone,
Old 03-26-2011, 02:53 PM
only one time, goes away until apply brakes again.
1997 Pontiac Grand Prix GTP HELP! aestheticguitar Grand Prix 9 04-23-2008 12:22 PM
1997 pontiac grand prix trans ?? wbauer Grand Prix 2 10-08-2007 07:36 PM
1997 Pontiac Grand Prix wiper transmission timing? srsssaddington Grand Prix 0 02-14-2007 05:02 PM
Orifice Tube - 1997 Pontiac Grand Prix Michelle Lewis Grand Prix 1 11-12-2006 09:21 AM
1997 Pontiac Grand Prix Jam Nut BIGPROFITT Grand Prix 4 08-13-2005 10:45 AM
