Old 03-26-2011, 06:30 AM
bsr2002 bsr2002 is offline
Question Strange noise
After I start my car I hear a howling noise. The sound doesn't increase or decrease when I press or depress the gas pedal. Inside the car it sounds like it's coming from under my back seat. When I go outside and listen underneath it is louder of course but coming from that same general area. No codes on the meter.
Could it be my fuel pump fixing to go out???
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 03-26-2011, 09:07 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Strange noise
Sounds like.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
The Following User Says Thank You to jeffcoslacker For This Useful Post:
bsr2002 (03-26-2011)
Old 03-26-2011, 01:10 PM
inafogg inafogg is offline
Re: Strange noise
you could listen with the engine off.have someone turn key to on
you only have a few seconds before pump shuts down but that will
comfirm if its the pump
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
Old 03-26-2011, 03:06 PM
Re: Strange noise
Is there anything special I should be listening for? When I turn the key I hear it engage.
Old 03-26-2011, 05:40 PM
Re: Strange noise
no,i was just saying to listen w/engine off so you could verify
that it is or is'nt the pump making the noise your hearing
if it is the pump(like you think)is it ready to quit? not really
you can check the pressure.pumps usually start to loose pressure
gradually, rare to just stop but is possible & have seen.nomal to
have estended crank or hard start when going bad.
hope this answers your ??
Good luck
Live For Today
Yesterday is gone,
Old 03-26-2011, 08:24 PM
Re: Strange noise
Good luck
I had a pump suddenly go out on me with a Sunfire a few years ago, prolly why I'm paranoid about it...
I will check the pressure, where is the test port for the fuel pressure located?
Old 03-26-2011, 09:14 PM
Re: Strange noise
if you look from r/f passenger fender the end of the fuel rail,the screw
cap will be pointed towards you.
took me awhile to find first time i looked on mine(96 3.1)
Good luck
Live For Today
Yesterday is gone,
Old 04-01-2011, 09:09 PM
Re: Strange noise
Good luck
I'm reading 41 psi on my gauge is this good?
Old 04-01-2011, 11:05 PM
Re: Strange noise
Good luck
Actually toady after riding around, I was leaving the store when it started making that sound as I turned the key on.
strange noise WDF!!! straughter Galant 1 08-13-2010 07:43 PM
car dead rotten egg smell, strange noise yall Intrigue 11 04-28-2010 07:11 PM
Strange Noise... changedagame108 Tires and Wheels 2 04-03-2002 02:17 PM
Strange noise after each engine start gthang Maintenance 2 03-14-2002 06:21 PM
Strange Noise Weedy 3 Series 0 02-27-2002 04:51 PM
