Old 03-24-2011, 04:26 PM
hufhouse's Avatar
hufhouse hufhouse is offline
Idle Air Control
Can a bad Idle Air Control cause surging during driving, say 35-45 MPH?
The car idles just fine.
Old 03-24-2011, 04:43 PM
inafogg inafogg is offline
Re: Idle Air Control
no whats going on
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 03-24-2011, 06:11 PM
hufhouse's Avatar
1996 Grand Am SE, 4 cyl
The engine surges while going down the road.
I'm also leaning toward something in the front passenger axle and suspension, causing something strange in the CV joint.
Old 03-25-2011, 06:23 AM
hufhouse's Avatar
I've replaced the fuel filter and the fuel pressure regulator, but I still get a feeling of the engine surging while driving...RPMs fluctuating up and down like it's staggering.
However, it seems to be related to travel in the suspension. I notice that the surging seems to happen in relation to the car dropping down...when you feel heavy in the seat. I also hear transaxle noise from the front passenger side at the same time. I get the feeling that there's something that is "disconnecting" when the suspension travels to its lowest point.
So, rather than the engine surge being caused by a fuel problem, I'm thinking the engine may somehow be "disconnecting" from the front passenger tire due to a bad axle or CV joint which causes the engine to race temporarily.
Unfortunately, transaxles and suspensions are a mystery to me.
Old 03-25-2011, 02:11 PM
your discriptions ''heavy in the seat'' &'' I get the feeling that there's something that is "disconnecting" when the suspension travels to its lowest point''.
need a better discription
have you scanned for codes,checked for vacuum leaks?
what made you change fpr a guess,a dtc,or someone said it might be the proplem
take a look at MAP sensor vacuum hose may have a crack i had this before
Live For Today
Yesterday is gone,
Old 03-27-2011, 06:57 PM
hufhouse's Avatar
Well, you were correct on the MAP sensor vacuum hose. It had a tear.
I replaced it, and the engine power increased dramatically. However, I'm still having hesitation problems under load.
Forget about the suspension stuff...it's unrelated. I do think I'm going to need an axle on the passenger side, but that's a separate problem. It's vibrating when the car dips low, which was causing me to think it was related to the hesitation.
Anyway, I'm still stumped by the hesitation after replacing the MAP vacuum hose. It helped, but didn't solve the problem.
I'm also getting P0304, cylinder 4 misfire codes.
I'm starting to wonder if I just need a new spark plug. The plugs were replaced about 10,000 miles ago, though.
Old 03-28-2011, 12:09 AM
thephantom1492 thephantom1492 is offline
wrong spark plug type or gap can cause issues...
mine ask for iridium spark plugs. I read somewhere else that someone put cheap standard plugs in it and didn't lasted 10k miles...
I would pull out the plug and check for wear and all... maybe swap with another cylinder... see if the code move...
Old 03-28-2011, 06:43 AM
hufhouse's Avatar
I was thinking about this overnight.
The broken MAP sensor vacuum hose would make the engine run too rich. It has been doing that for some time now.
I wonder if the plugs are just fouled?
Could be a simple, cheap solution.
Old 03-28-2011, 11:55 AM
what codes are being read??
Live For Today
Yesterday is gone,
Old 03-28-2011, 12:40 PM
Scrapper Scrapper is offline
AF Premium User
have you tried doing a compresion check on this? and it could very well be a axle going into tranny.
Old 03-28-2011, 05:00 PM
hufhouse's Avatar
Only code is P0304, misfire on cylinder four.
No compression check. Truthfully, don't even know how.
Old 03-28-2011, 08:30 PM
as I said, check the plugs, swap them with another cylinder... let's say you swap with 3, if you get a P0303 you know that the prob is the sparkplug.
I doubt the coil is the problem, as it fire on 2 cylinders so you would get 2 codes or a random misfire code.
if you still get P0304 after the swap, I would then check the compression.
Old 03-30-2011, 09:10 AM
AF Premium User
try to rent a guage from autozone you take it back you get your money back or you can try advanced. it theards in like a plug does and guage at the other end.
Old 03-30-2011, 09:38 PM
Blue Bowtie's Avatar
Registered Offender
Actually, a failing coil can create weaker spark on one of the plugs in a "wasted spark" system. It depends upon the failure mode of the coil.
Old 03-31-2011, 07:54 AM
skeeter123 skeeter123 is offline
Are you sure it's not a transmission prob (unrelated to the P0304)? If it's an automatic, it may be having trouble locking into gear. Try running in "3" to keep it from seeking overdrive, see if the surging goes away.
Hope this helps.
ICV Idle Control Valve not working squawcrk Cavalier Problem Diagnosis 1 07-03-2010 01:04 PM
95 2.2L fast idle problem - idle air control? POPPABUSA S-10 2 07-30-2008 12:36 PM
Idle air control valve, bad idle bigjerr Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 10-26-2006 01:22 AM
FS: Idle Air Control ( IAC)- Idle Sensor Control (ISC) Killa Classifieds 10 09-22-2006 11:16 PM
94 Plymouth Voyager WON'T IDLE AHHH! Not EGR Not Idle Air Control HEELLLP! dadscarisaheadache Caravan | Voyager 3 03-28-2005 02:56 PM
