Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-24-2011, 03:46 PM
vtwindave vtwindave is offline
2000 gm spark plug replacement
any "tricks" or things to watch out for when changing spark plugs? looks like the fuel rail has to be moved, any issues with this? thanks.
Old 03-25-2011, 07:05 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 2000 gm spark plug replacement
Fuel rail does not have to be removed. Once you unbolt the Coil-On-Plugs (COPs), they can be twisted a bit and pulled right out as they have rubber boots.
Some things to note:
  • Be sure the engine is cooled down completely to room temperature, especially before torquing the new plugs.
  • Do NOT use anti-seize, oil, or any type of lubrication on the spark plugs. This will cause over-torquing and stripped threads.
  • Tighten to 16 lb-ft and NO MORE or you can strip the already very weak threads in the head.
  • Do not over tighten the COP bolts very hard, either. They are just tightening down to a brass fitting in the composite intake manifold and the brass fitting can easily come loose.
  • You will probably break some, if not all, of the retention tabs on the fuel injectors if you disconnect them to make room. This is a non-issue as long as you ensure they are put back in place pretty good. Some people recommend zip-ties, but I have had no issues without anything holding the connectors in place.
  • Get a long extension as this will make the job much easier....especially the rear passenger side plug.
  • Before installing the COPs, inspect the boots for cracks and holes. Clean the old grease and debris off. Then apply dielectric grease to the ends of the boots to keep moisture out and an air tight seal between the plug and COP boot.
  • Gap to .054". Do not assume they are pre-gapped. Measure and adjust the gap as necessary.
  • Do NOT use Bosch spark plugs. Stock with Motorcraft or Autolite (manufacturer of Motorcraft spark plugs). I am running Autolite double platinum APP103's which are one heat range colder than stock (for good reason).
I see you are in the Cleveland area, too. If you need help, just ask.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 03-26-2011, 09:16 PM
Thumbs up Re: 2000 gm spark plug replacement
thanks for all the info, it really helped out! i have to get a manual for this car but i like the info from someone that has "hands on" experiance. i changed all the plugs before work today, easier than i thought. installed the autolite platinums
(blue fusion, what part cle are you in? i'm in medina)
Old 03-27-2011, 09:38 AM
Glad to hear it went well. I'm in North Royalton near the Parma border.
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 09:19 PM
spark plugs freakyfire05 ZX2 2 02-17-2009 12:03 PM
spark plug replacement 3.0 engine 2000 Grand Voy. dealseaker Caravan | Voyager 3 08-19-2006 11:44 PM
2000 dodge minivan spark plug replacement bearsfan_54 Engineering/ Technical 0 11-12-2005 03:46 AM
2000 Spark Plug Replacement kentboyle Sonata 2 07-23-2005 01:05 PM
