1996 C1500 tail light fiasco
I have a 96' C1500 pickup that has an on again - of again issue with the drivers side rear tail light. It will work fine then all of a sudden you get the old quick flash and the light working. I have cleaned it, check the wires, can find nothing. Usually the darn thing starts working as I work on it. Are the circuit boards on these a common failure? That is the only thing I can think to try
I used to be indecisive, now I am not so sure. |
Re: 1996 C1500 tail light fiasco
I've had a similar problem with my '95. It wouldn't go out, but the taillights would dim and the bulb out warning light on the dash would be lit up.
Turns out it was the wiring connectors that plug into the light. They had loosened enough that the contacts were not very good and they had oxidized. Try carefully using needle-nosed pliers to pinch them back closed and insert/remove them a few times to scrape off the oxides. Good luck!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
If you have the standard old style lamps , the cleaning of the socket, replacing the bulb and on the bulb connections you apply a good amount of silicone electric grease. with this grease on the lamps the connections are less apt to cause connection issues. this can also be applied to the connectors that supply power here. |
Yes, the circuit boards have been an issue. Usually due to the cold solder technique used during assembly. NAPA has replacements fairly cheap.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
I this common issue? Do you live under a rock??
Yes... O'Reillys stocks the tailight assemblies on the shelf-- bought both for my B-I-Ls Yukon- $43 I think for set of two. The GM parts counter man actually told me to go there-- amazing!
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
LOL, NO I don't live under a rock...but may soon if the government has anything to do with it....But seriously sorry for the slow reply. I have never had to deal with this type of socket assembly. The old styles are no big deal and easy to fix. This turned out to be the board as the turn socket only was acting up. I d/c it and the metal was disfigured, which I did not catch when I cleaned the crud out of it. Looks like a nice newer way to screw something that worked up. Anyway I have it working again fine but I have to replace the entire RIGHT side too as I found the brackets were broken and I guess Red Green must have owned the truck as the right side was being held in with DUCT TAPE. So I think maybe I'll just replace them both with aftermarket units complete with boards. I will check NAPA though first. If the board is cheap enough I guess I could go ahead and keep the left lense assembly.
