Old 03-22-2011, 04:49 AM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
pesky top shock nut
I have an 88 c1500 that had the lower ball joint fail/seperate on us. The ball joint came through the lca and is still hanging on the spindle. The control arm fell to the ground (along with that side of the truck)
Anyhow we bought a whole new LCA assembly to put in. I went to take the shock off and i cant get the nut on the top to come out. Iv been using an impact on it with lots of pb blaster and it just spins the whole shock shaft. Tried locking plyers on the flat on top and a wrench, but cant get enough torque as its a bit akward to get at.
Any tricks/suggestions to get this off? I'm just about ready to pull out the angle grinder and buy a new shock lol.
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 03-22-2011, 06:27 AM
slo99sierra slo99sierra is offline
Re: pesky top shock nut
This would be a good time to buy new shocks IMO.
However...You could use vise grips on the shaft, hold it there then hit the nut with the impact.
1999 GMC Sierra RCSB 4.3L V6 overall stock plus some exterior and interior work.
The Following User Says Thank You to slo99sierra For This Useful Post:
helliviknow (03-26-2011)
Old 03-23-2011, 02:07 AM
I tried something to that effect to no avail. I think the problem is that the threads just rusted beyond help lol. I think I'm going to give it one last shot tomorrow then the grinder is comming out and the old beast will get treated to new shocks
AR 15" Baja's
K&N FIPK
Old 03-23-2011, 06:16 AM
snshddog snshddog is offline
All I ever do is use a socket and a long extension when You can get at it from the top like in a truck. Bend it as far as you can back and forth until it breaks.
The Following User Says Thank You to snshddog For This Useful Post:
Old 03-23-2011, 06:25 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Get the ball joint in before taking the shock lose.
The Shock may be holding spring tension.
Cuting/grinding the shock lose without ball joint hooked up could cause a lose of fingers or feet.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
Old 03-23-2011, 08:17 AM
j cAT j cAT is offline
with the lower mounting studs removed and a vise grip pliers clamped on the shaft just below the lower mounting washer heat the nut with a small tiped propane torch until it glows red then using the air gun at low torque it should come off easy ..it is quite possible locktite was used on this ..
The Following User Says Thank You to j cAT For This Useful Post:
Old 03-26-2011, 01:05 AM
The torch did the trick
couldn't get it to glow (the rust? lol) but i got it nice and hot and hit it with the impact and it zipped right off! Before this i went ahead and unhooked the bottom shock mounts and took the spring out so i could get a better grip on the shaft of the shock. not sure i created that much friction as smooth as it is lol. I contribute most of this to the heat!
Thanks everyone for the replies! I think we are going to just give this old truck a proper fixing up at this point. It has served me and my family very well for a very long time.
AR 15" Baja's
K&N FIPK
HUGE Wheel Lock nut issue! Need help finding the right key/socket to fit! Passatguy Tires and Wheels 4 08-31-2010 11:46 PM
Rear Air Shocks stuck fully extended phantomyj Silhouette 1 10-09-2009 03:54 PM
Help with frozen track bar and shock nuts! jcb18 Rodeo | Passport | MU 1 07-20-2006 11:01 AM
how to remove upper front shock nut on 86 towncar bowman1268 Town Car 0 12-02-2005 09:27 PM
KYB AGX shock, nut wont tighten aprather24 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 12-15-2001 06:23 PM
