Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 03-20-2011, 12:41 PM
macika3 macika3 is offline
92 corolla tachometer hook up!
i got a 92 corolla 1.6 5 speed manual without a tach,i have an after market tach with 4 wires coming out of it red,black,green, yellow,i need help where and how to hook it up thx!
Old 03-20-2011, 04:54 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 92 corolla tachometer hook up!
You don't mention the specific brand of meter...most of the time you can look up the installation sheet/manual online, which I HIGHLY recommend when dealing with ignition components.
But in general, the four wires are typically as follows:
Green: goes to the negative side of the ignition coil or the tach output terminal of your OBD-I port.
Red: switched and fused 12-V power
Yellow: 12-V power from the instrument panel lighting (controls the meter's backlight)
Black: ground wire
There is probably also some switches under the back cover of the meter to change it to read 4-, 6-, or 8-cylinder engines. You may have to guess and check on this, but for DIP-style switches, 4-cylinder is usually both switches either ON or OFF.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-20-2011, 06:36 PM
Black: ground wire
Hope this helps!
its made by glow shift!thx
Old 03-21-2011, 03:17 PM
jdmccright's Avatar
The RustBuster
I was close. Here's a install sheet for one of their gauges:
http://www.glowshift.com/instruction...Tachometer.pdf
Find your specific model and compare features. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
The Following User Says Thank You to jdmccright For This Useful Post:
macika3 (03-21-2011)
tachometer hook up wire for a 2001 Crown Vic Police Interceptor sgtnitro Crown Victoria 1 01-08-2006 12:05 AM
Tachometer hook up SierraK1500 S-10 4 06-12-2005 06:52 PM
tachometer hook up? yamaha125 Contour 0 05-09-2005 04:49 PM
B16 Sir How Do I Hook Up A Tachometer rubnzracen How-To's and Walk-Through's 5 04-13-2005 10:30 PM
