Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-07-2006, 08:47 PM
sgtnitro sgtnitro is offline
Thumbs up tachometer hook up wire for a 2001 Crown Vic Police Interceptor
Has anyone hooked up a tachometer to a 2001 CVPI or civilian crown Victoria? What color is the RPM wire from the coil and where can it be found. I know the older models use tan with a yellow stripe, but I was told that it had changed after 1999. Any suggestions?
Old 01-08-2006, 12:05 AM
reekor reekor is offline
Re: tachometer hook up wire for a 2001 Crown Vic Police Interceptor
TACHOMETER white/pink PCM DR Rear Engine near Master Cylinder, 1 Cylinder Setting
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
