Old 03-19-2011, 04:45 PM
Carporg Carporg is offline
Front Axle
I'm hearing a grinding when the steering wheel is turned any at all to the left on my 2005 LeSabre. I don't think it's the hub assembly because I changed it not long ago. Would it be safe to assume the axle may be worn out?
Old 03-19-2011, 06:21 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Front Axle
If the sound starts as soon as the steering wheel is turned even a very small amount to the left, then your steering rack may be at fault.
If the noise only occurs during faster cornering, then it may be a wheel bearing.
Leaking front axle seals GeoPete Metro 2 12-16-2010 12:02 AM
Leaking Front Axle Seal (With Pictures) wagslick Silverado 10 11-27-2010 08:14 AM
Front Axle and Rear Axle Fluid Volume kevin9333k Yukon 4 11-06-2009 10:57 AM
Tags
axle , noisy
