Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 03-19-2011, 12:08 PM
rob cole rob cole is offline
No fuel new pump
I have an 88 g-10 with the 4.3 v 6 TBI I Have no fuel at the throttle body so I thought fuel pump . I replaced the pump and filter and still no fuel . I can see the throttle body and not a drop is coming out. pressure tested ok nothing is going to return line and strangely the pump runs 15 seconds after the key is turned off, (after trying to crank) I don’t remember hearing it run after key off before. I can pour some gas down the hatch and it runs good for long enough to burn that up not sure what to try next. any suggestions would be most helpful
Old 03-19-2011, 04:15 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: No fuel new pump
First make sure fuel pressure is up to specs.
9-13 lbs key on and engine cranking.
If good there check for 12 volt power to positive side of injectors.
If no power there check fuse.
If 12 volt power there and still no start check for injector pulse while cranking.
Post back what you find.
MT
Old 03-20-2011, 11:08 AM
Thanks I will do the pulse check today. the pump tested at 14 lbs so that looks good and I disconected the line and got soaked with fuel so I know its getting up there good. If the pulse is not getting power what next?
Old 03-20-2011, 04:16 PM
MT-2500's Avatar
AF - Advisor
The pulse is a ground pulse.
But do not go grounding the circuits.
That can blow PCM.
Only check for pulse with a injector tester noide light.
One step at a time.
1- fuel pressure while CRANKING.
2- 12 VOLTS TO INJECTOR CRANKING.
3- INJECTOR PULSE WHILE CRANKING
IF ALL 3 IT SHOULD START.
Are you getting 12 volts to neg side of injector?
If so then check pulse with injector pulse noid light.
Let us know what you find.
MT
Old 03-20-2011, 05:44 PM
Thanks for the info I will post my findings tomorrow
Old 03-29-2011, 02:57 PM
Got 12 volts no pulse now what this thing needs to go. THANKS !!!
Old 03-29-2011, 07:48 PM
rhandwor rhandwor is offline
A junkyard distributor should get you going.
Old 03-31-2011, 07:51 PM
Why would a distributor need replaced checked the icm inside it was ok. I am slow to post I may also be slow understanding this thing fires right away when primed till fuel gets burned. Thanks for your reply/s
Old 03-31-2011, 09:43 PM
http://www.ehow.com/how_7419690_1988-gmc-pickup-coil-installation.html I don't understand how it fires with no pulse which you stated earlier.
Old 03-31-2011, 10:54 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
If your pump is working nd you are getting fuel up to the injectors, I would focus on this portion of the problem. I would check your fuse for the the injectors and see if you get power and ground.
Old 04-02-2011, 12:05 PM
All fueses good power at the injectors no ground pulse as I said before looks like its probably the ecm its letting it fire but thats all only 100.00 bucks but what if I buy that and it doesnt fix the pulse ( broken wire someplace? ) Then I will call tow truck to haul it off ( so frustrated) I have been working on this sence there was 15 inches of snow on the ground tomorrow its 80
GTP fuel pump resistor problem... gtp4life Grand Prix 12 01-24-2010 10:32 AM
fuel pump rcweston Lumina 2 12-29-2009 11:38 PM
97 GS, Fuel Pump Not Running sea-doin-it Regal 5 12-12-2009 09:21 PM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 07:12 PM
88 Lebaron Turbo - no power to fuel pump 1988lebaronturbo Lebaron 3 05-02-2009 04:30 AM
