Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > 1969 - 1994 Full size
Old 03-18-2011, 06:07 PM
jameswery69 jameswery69 is offline
89 blazer help
89 k5 5.7 auto got a prob wants to stall and is idling badly now acts like its cutting out as in missfire have replaced fuel pump filter injectors plugs wires cap rotor temp sensor o2 sensor egr clean and vacuum test was good... seems that when outside tempis in the 30s it runs great untill heat build up under hood 50s or warmer runs like crap from the gitgo any help would be greatly apriciated and needed... im not a mechanic but am able to do work myself and have decent knowledge in this area but am stumped with this one also only code it throw is 44 lean
Old 03-19-2011, 06:13 AM
LTZ89 LTZ89 is offline
Re: 89 blazer help
Possible causes. O2 wires touching exhaust, bad ground from ECM to engine block.
faulty MAF or vacuum leaks.
you can unplug the MAF and if the problem goes away replace it.
90 s10 blazer 4.3L stalling, erratic idle.. please help! gunner0352 Problem Diagnosis 6 09-18-2009 08:31 PM
inexperienced with 96 blazer, please help 96t10 Problem Diagnosis 2 06-11-2009 07:56 AM
93 S-10 Tahoe Blazer Help Needed !!! s10tahoemomma Blazer 3 04-15-2004 05:12 PM
Need Blazer Help??? probie6556 Blazer 5 02-23-2004 08:36 AM
starter from 86 s10 blazer fit & work in 88 s10 blazer help pleEASE!!!! juzdose S-10 1 12-20-2003 06:36 PM
