Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 03-18-2011, 05:48 PM
DAVE K DAVE K is offline
Cannot find coolant leak
I have a 93 aerostar 3.0 auto.and the problem is it keeps going down on coolant and I cannot find a trace of a leak anywhere,(have anti-freeze)I did change the water pump however,no water or anti-freeze on floor,or outta tailpipe or windshield or under the van anywhere,nothing on dipsticks-except whats suppose to be.
It doesn't go down fast,maybe oh 2-3 qts. every 50-60 miles.It seems way to much to the point that I carry water.I'm pulling some hair out here and it's hair I can't afford. LOL.Kinda.
Old 03-18-2011, 06:12 PM
danielsatur danielsatur is offline
Re: Cannot find coolant leak
Consider Metallic block seal, so you don't have to chase down leaks.
Old 03-18-2011, 11:28 PM
Originally Posted by danielsatur View Post
Consider Metallic block seal, so you don't have to chase leaks down.
I have thought about it, however wouldn't there be some trace even a few drops
somewhere?but I guess it couldn't hurt though, just like to find where it's going.
Old 03-18-2011, 11:47 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Try and avoid adding anything if you can.
From my experience they tend to do more damage than good, and are only ever intended as a last resort get you home fix.
If it is missing from the radiator then it has to be going somewhere, and you will be able to find it.
Start by replacing the radiator cap. This may not fix the problem, but may instead make it bad enough to spot.
My car recently had a loose fitting on the radiator, but as the radiator cap was bad it never built enough pressure to show up easily.
When I replaced the cap, the leak became obvious.
Then clean the engine bay, it's possible the leak is hidden under a layer of road grime.
Next it's simply a matter of checking everything with a torch while the car is running.
If you can, put the car up in the air, on a hoist is best, but on axle stands will do.
Leaks are usually easiest to spot from underneath.
You may have to remove some under body trays etc.
Note, using a torch really does make a difference.
Old 03-19-2011, 12:00 AM
tempfixit tempfixit is offline
Moppie, I have not heard of the torch method before can you explain? Do you use the flame or with torch just on? Interesting?
Dave K, have you checked spark plugs for evidence of coolant being burned. Whiteish tips. Also have you done a compression test to see if head gasket is leaking?? Co you have any bubbles inthe coolant resorvoir or radiator?
Old 03-19-2011, 12:25 AM
=tempfixit;6882337]Moppie, I have not heard of the torch method before can you explain? Do you use the flame or with torch just on? Interesting?
Flashlight. I looked twice myself.
I admit I haven't checked the spark plugs(real pain in the *&# to get to)but I have no coolant in oil or at tailpipe or anything showing up in radiator tank.oil ,bubbles etc. found a few drops of tranny fluid on the driveway though.
Old 03-19-2011, 12:47 AM
Moppie's Avatar
Master Connector
The wonders of international forums
I can only imagine how much damage you could do with a blow torch
Old 03-19-2011, 01:13 AM
Caught me off guard for sure,just for a second or two I wondered if I might find that gas leak
Old 03-19-2011, 01:13 PM
PICKUP6772's Avatar
PICKUP6772 PICKUP6772 is offline
Send a message via AIM to PICKUP6772 Send a message via MSN to PICKUP6772 Send a message via Yahoo to PICKUP6772
Dave,
It sounds to me like you might have a coolant leak in to the combustion chamber. You're not finding anything because it's burning right up with the fuel mixture. I would definitely have the cooling system pressure tested. Pump it up to about 18 LBS., and let it sit for about a half hour. If there is an external leak, it will rear it's ugly head. Also listen to the air cleaner intake tube, and the exaust pipe. If there are any leaks in those areas, you might hear a hissing, or bubbling sound coming out. One last thing to try is a dye kit. this gets added to the coolant. you let the van run until it gets hot, and the t-stat opens. From there you use an ultra violet light, and a pair of special goggles to look around the van. Where ever your leak is will light up like the fourth of July. I know this is a little wordy, but I hope it helps.
MIKE
MIKE
The Following User Says Thank You to PICKUP6772 For This Useful Post:
DAVE K (03-19-2011)
Old 03-19-2011, 01:42 PM
Flashlight did not even enter the mind. Just didn't make sense
Old 03-19-2011, 04:13 PM
Check the weep hole on top of the water pump.
Old 03-19-2011, 07:48 PM
Its a new pump,but I have though.But new don't always mean good.Actually rebuilt.
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
1995 4wd 4.3 vortec... hard to find coolant leak. vballfun Problem Diagnosis 4 08-15-2008 06:12 PM
98 Monte Carlo Z34 Cant find coolant leak JWILL1015 Monte Carlo 1 07-07-2008 04:52 PM
