Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 03-18-2011, 11:54 AM
kirley09 kirley09 is offline
Exclamation Check Engine Codes HELP PLEASE (im a girl on a budget :( )
2001 Hyundai Accent GS 1.6L 2door hatchback Automatic transmission 109k miles
Got the check engine light 2 days ago, too it to Meineke and they told me the following
PO133 Oxygen Sensor Bank 1 Sensor1 $80 labor/$160 o2 sensor
PO722 Gear 3 ratio incorrect
PO733 Output shaft speed sensor no signal $130 labor/$243 sensor
He said the problem is with the transmission.
I know where to get the o2 sensor, but where can I get the right speed sensor? I found like four different types i don't know which one.
Anything else I should know, suggestions? anything really?
Im on a budget and this is my first car. i drive to school everyday so it cant break otherwise im screwed.
Thanks.
Old 03-18-2011, 03:33 PM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
Re: Check Engine Codes HELP PLEASE (im a girl on a budget :( )
I hope you don't pay $160 for the oxygen sensor. List price from Hyundai is $94.15. You should be able to find a dealer to sell it to you for that. If not, I will, and include shipping.
P0722 is for the output speed sensor, and P0733 is for the incorrect gear ratio.
The output speed sensor on this vehicle comes with the input speed sensor, and is called a pulse generator. I'd be finding another shop to do the work, because their prices are outrageous. The pulse generator lists at Hyundai for $44.67, and it is very easy to change. They should not be charging you $130 in labor to change it.
The incorrect gear ratio typically means you need a new transmission. It is detecting slippage with 3rd gear. Every once in awhile, a transmission service will fix this concern, but not very often.
If you do want the parts, I will sell you both parts for $115, shipping included. I have both parts in stock and can ship out on Monday.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 03-18-2011, 04:30 PM
danielsatur danielsatur is offline
A universal HO2 sensor for $35 should be good enough!
see http://www.autopartswarehouse.com ,
If you get a new VSS, it may resolve your Transmission problem.
Check engine light help please! OBDII code P1456 JaimeZX Accord/TSX/Accord Hybrid 0 11-06-2004 03:46 PM
Check Engine codes Help H60ip Neon | Plymouth Neon 2 10-31-2004 02:33 AM
Check Engine Code Help!! filipnoy85 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 05-13-2004 03:51 PM
1992 Buick Regal check engine code help redlines4us Regal 11 07-11-2003 11:46 AM
