Old 03-17-2011, 09:06 PM
fomoco1912 fomoco1912 is offline
Unhappy 98 taurus won't start?
1998 Turus turns over but will not start, it ran just fine till the next morning and all it did was crank but nothing else. Any ideas? anybody!
Old 03-17-2011, 10:39 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 98 taurus won't start?
You're going to need to do some troubleshooting before we can give you much more for suggestions, such as what's missing, spark, proper air/fuel ratio, or compression? The easiest to check for may be to use some throttle body cleaner in the throttle body to see if the engine sputters or maybe even starts, indicating a lack of sufficient fuel. If you have a spark tester, check for spark on a few cylinders. I'm not sure I'd worry about compression yet unless you have a compression tester handy.
-Rod
Old 03-18-2011, 06:23 AM
shorod's Avatar
SHO No Mo
Oh, one other thing to try is a different, programmed, ignition key. Take note of the Security/Theft indicator - is it on or flashing when attempting to start the car?
-Rod
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
My 2002 Taurus won't start at all now! sugarpop98 Taurus | Taurus Wagon 4 08-29-2005 08:42 PM
2001 Taurus won't start... scott/paula Taurus | Taurus Wagon 3 10-05-2004 05:31 PM
My '97 Taurus won't start.. Please help! teh_balzaK Taurus | Taurus Wagon 2 08-17-2004 03:24 AM
95 Taurus won't start and run 97Bird Taurus | Taurus Wagon 2 05-13-2004 07:26 PM
