Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-16-2011, 06:25 PM
reekor reekor is offline
Dome light
I'm working on an 08 P71 ex-police. The dome light does not turn on when the doors are open, while it works just fine if turned on via dimmer switch. The door ajar light on the dash does come on when the doors are open, but no dome light.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 03-16-2011, 06:42 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Dome light
If you work the switches on the dome light, will the lights work? A lot of the Police had an option to keep the dome light off when doors are opened for safety reasons when the officer was entering or exiting the vehicle.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-16-2011, 08:15 PM
Re: Dome light
Yup the light works fine when turned on with the switch. After looking at the wiring in the FSM it looks like the dome light is triggered via BCM. With that said. The BCM is sending power to the dome light when toggled by the dome light switch. The door ajar light on the dash comes on when the doors are open, so this tells me that the door sense is working fine. Which makes me think it's a BCM issue or the BCM has been programmed not to turn the dome light on with doors open for the reason you stated.
Old 03-17-2011, 10:28 PM
djh00cvpi djh00cvpi is offline
Re: Dome light
The P71 Crown Vics have a "Dark Mode" that disables the domelight operation with the doors. Here's what you need to do:
Look under your dash - specifically under the glove box. You will see a single wire with a blue harness plug. Unplug the two halves of the harness... you may want to tape or zip-tie the ends to keep them from hanging below the dash. Next... remove the Negative battery terminal for 10 minutes. That will deactivate the "Dark Mode" and your dome light will operate with the doors.
Old 03-17-2011, 10:53 PM
Re: Dome light
After searching the net for a while I found what the problem is with the light, you are right the BCM is in "Dark Mode" or " Dark Car" Mode. What you said about the wire is correct for 05 models and older. The 06 and newer models need the use of a factory scan tool to disable the "Dark Mode" or " Dark Car" Mode.
http://www.p71interceptor.com/fordids/screenshots/
Old 03-18-2011, 06:05 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Dome light
Drive it down and I will reset it for you.
Old 03-18-2011, 09:10 PM
Re: Dome light
That's one long hoof to Kentucky from Ontario. What scan tool do your own? I just picked up a Hickok NGS which is updated to 09 and has a CAN module. I'm hoping it will do the trick. Soon will know once it gets here.
Old 03-19-2011, 06:32 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Dome light
I purchased the IDS for the shop and liked it so much I got me one. Got it updated to 2011 and probably will stop updating. Going to quit working in a couple of years so I am trying to let my assistant learn the ropes. You should be able to do it with the NGS.
Old 03-19-2011, 09:19 PM
Re: Dome light
It seems that Ford is getting just as bad as Chrysler with module programming options,only difference is that Chrysler has been doing it since 1996.
VERY Hot Dome Light hot dome light man Grand Prix 5 10-02-2010 11:11 AM
2002 Express dome light issue jtram2 Express | G Van 2 07-23-2010 07:57 AM
TIP: Fix those doorjam switches // no dome light... Intuit Escort 3 11-21-2009 10:27 PM
Headlights & Dome Lights GirlLovesCamo Venture 1 11-01-2009 12:57 PM
Map lights stay on... cs2009 Bravada 2 07-01-2009 12:28 AM
