Go Back   Automotive Forums Car Chat > Mazda > MX-6
Old 03-15-2011, 11:03 AM
coalminer coalminer is offline
Send a message via Yahoo to coalminer
93 MX6 2.0 wiring problem
Im hoping that someone has seen this issue before, I was brought this car to see what is going on with it, was not getting any spark. I found another distributor in the junkyard and replaced it and was still not getting any spark, when I pulled the distributor and turned it by hand with the ignition on, the injectors would fire, but not the plugs. I added power to the black wire with a white stripe on the 3 wire plug and now it runs, but as soon as I remove that jumper wire it stalls.
Im asuming there is a short somewhere, but before I start tracing that wire back to the ignition switch, does anyone have any ideas where I should start? And the fuses in the box for the ignition are good, did check those first.
Any ideas would be appreciated!!!!
1999 Jetta GLS 2.0 AEG Fuel system problem Probe '97 - '03 3 04-20-2010 10:24 PM
2001 2.0 Jetta with 5 codes???? moemo '97 - '03 1 12-29-2009 05:22 PM
need vacuum diagram:'88 ram d-50,mitsu 2.0 liter cukoobajube Ram Pickup | Ram SRT10 0 05-31-2009 05:59 AM
94 jetta 2.0 Wiring diagram Boost192 '91 - '96 3 12-08-2003 10:20 PM
2.0 si problem outrun Prelude 4 06-10-2003 01:12 AM
