Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 03-14-2011, 01:40 PM
hangun61's Avatar
hangun61 hangun61 is offline
Question 93 Celica Drive Shaft
My 1993 Celica, 1.6, 5-speed manual left drive shaft failed and I am trying to replace it myself. I have the new part in hand, but for some reason, the inner splined shaft does not want to go all the way into the transaxle. I have tapped the rotor end of the shaft with a mallet and tried to force it in, but everything Ive tried wont work.
Any ideas? ANY help would be appreciated since my car is down for the count until I can get this drive shaft back in.
Old 03-15-2011, 03:17 PM
doug2060 doug2060 is offline
Re: 93 Celica Drive Shaft
Back it out and make sure theres no obstructions. If the is a ring at the end of the shaft make sure it is as centered as much as possible. Make sure it goes in straight. Good luck...
The Following User Says Thank You to doug2060 For This Useful Post:
hangun61 (03-16-2011)
Old 03-16-2011, 05:35 PM
hangun61's Avatar
Turns out I had the wrong part. '92 and '93 aren't the same. The splined shaft is a different size.
86 caprice. 305 to 350. drive shaft lengths? m3gas3th Caprice 11 05-12-2009 10:40 PM
driving without rear drive shaft jdsalas Cherokee 5 07-31-2008 07:11 PM
can i take drive shaft off and drive it front wheel? got mph 3000GT/Stealth 1 09-01-2004 01:24 PM
S-10 drive shaft vibration StevanSimmons S-10 1 02-05-2004 03:51 PM
Advice on new clutch/drive shaft. stesta5074 3 Series 1 10-15-2002 01:22 AM
