Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 03-13-2011, 09:10 PM
YAMA230 YAMA230 is offline
1996 3.1 tcc
Hi i was wondering if theres any way to unplug the TCC on 1996 monty carlo LS also and instructions on how to change it? My car surges and i hooked computer to it and shut the TCC off and the surging stops so i think thats the problem any helps appreciated thanks
Old 03-30-2011, 09:29 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Re: 1996 3.1 tcc
Umm....The TCC that you are referring to is the Torque Converter lock up Circuit, correct? If so, then it is inside the transmission and you can not just unplug. If you do so, you will burn up the transmission. In order to check it properly, you will need to do a resistance test on the wires to the TCC solenoid and see if it is gettind the proper ground and power as well. To change it, you will need to support the engine and transmission and drop the subframe, angle the engine and trans down enough so that you can remove the transmission side cover and go from there.
1991 Cutless supreme 3.1 stalling mandude Cutlass Series 9 02-06-2015 12:16 AM
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 06:37 PM
2002 3.1 thermostat removal DigduG1975 Grand Prix 1 05-29-2010 08:47 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
3.1 interchange info please. Ponyak Grand Prix 2 06-08-2009 10:58 AM
