Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 03-13-2011, 02:41 PM
thiscarsucks thiscarsucks is offline
89 Corolla, Running very rich
So, I have an 89 toyota corolla, and it seems to run very rich, which is eating up my gas mileage. I think I heard something about adjusting something on my carburetor? How do I do this?
Old 03-15-2011, 09:40 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 89 Corolla, Running very rich
You may be due for a carb rebuild. If the little float inside the carburetor is stuck in the down position, or the little valve plunger is worn or gummed up, this can overflow the the bowl and allow excess fuel into the intake.
Also check that all of your vacuum lines and the carb base gasket is airtight by spraying around them with carb cleaner while the engine is idling. If the engine stumbles or stalls, you found a leak. A carburetor rebuild kit will have all the replacement gaskets and o-rings needed.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
'90 PA error code 13, runs very rich!! swissimeister Park Avenue 2 05-22-2007 09:02 PM
1991 GM 3.1L engine running very rich and can't accelerate! Scott-Ohio General Discussion 4 03-07-2007 06:05 AM
92 PA Ultra Running Very Rich N55340 Park Avenue 2 04-24-2006 07:00 PM
Runs Very Rich MRPEPPERRR Blazer 2 11-10-2005 09:03 AM
sohc ZC running very rich SIvic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-06-2003 10:18 AM
