Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-12-2011, 10:16 AM
L22 L22 is offline
1990 olds 88 MAF
1990 olds 88
I just received code 34(There was no MAF signal for over 4 seconds while engine was running.)
Does this mean that it's faulty and must be replaced? or Is it possible clean or repair it. It looks like an expensive part.
Old 03-12-2011, 12:23 PM
Blue Bowtie's Avatar
Registered Offender
Re: 1990 olds 88 MAF
I've had this on a couple of Buick Series I 231 engines. The electrical connector for the MAF is just as suspect as the MAF itself. As I recall, a replacement MAF is a couple hundred bucks.
The Following User Says Thank You to Blue Bowtie For This Useful Post:
L22 (04-14-2011)
Old 03-12-2011, 01:50 PM
L22 L22 is offline
The check engine light went off on the next start. It seems to be running ok...I guess I'll just keep my eye it
Old 03-13-2011, 11:39 AM
L22 L22 is offline
Check engine light came back on....I guess I will try cleaning before replacing. Do I have to use MAF cleaner or will brake cleaner or other solution work?
Old 03-13-2011, 12:11 PM
Scrapper Scrapper is offline
AF Premium User
yes you should get the cleaner like you clean throttle body with you can get it at autozone or about any parts store. while your doing that i would look inside throttle body at thje butterfly if it's dirty clean that as well.
Old 03-13-2011, 04:40 PM
L22 L22 is offline
I cleaned the maf sensor....No code yet. The car does hesitate sometimes when accelerating as it always has
Old 03-15-2011, 11:07 AM
L22 L22 is offline
The car seems to stumble and actually did stall one time when I started tapping on the MAF while running. Is this a conclusive test that the maf is bad…Justing try to be sure since I’m going to pay a hefty price for a replacement MAF.
Thanks
Old 03-17-2011, 01:55 PM
L22 L22 is offline
Went to the junkyard and found a MAF for $25....Installed and it seems to be running ok
Old 04-12-2011, 06:38 PM
L22 L22 is offline
Well, the car started running bad and I got the code 34 again. Its running like does when the MAF is unplugged. What are the chances that I have a bad MAF(just replaced from junkyard) or there is a problem with the wiring.
Old 04-12-2011, 07:31 PM
maxwedge maxwedge is offline
A990 racer
Look at the harness connector, they tended to pull apart or corrode as Blue Bowtie pointed out, and yes the junk yard unit could be bad, why not?
The Following User Says Thank You to maxwedge For This Useful Post:
L22 (04-12-2011)
Old 04-18-2011, 12:44 PM
L22 L22 is offline
The junkyard unit did indeed go bad.
2000 Olds MAF Clean/Replace js39 Silhouette 2 02-08-2011 11:26 AM
1990 TC MAF sensor Location enigma58 Town Car 2 10-06-2005 03:26 PM
1990 olds royal 88 stalls & has short duckdiver Eighty Eight 3 01-08-2004 08:36 AM
1990 Olds still missing bvanemon Eighty Eight 3 12-28-2003 08:08 PM
1990 olds cutlass supreme blueeyes101675 General Discussion 2 12-27-2003 08:11 AM
