Old 03-10-2011, 04:34 PM
corvettekid_7684 corvettekid_7684 is offline
Help: vinyl tires & clear
I need to add some decals to some vinyl tires. I have had bad luck with spraying clear (Krylon) over them to seal the decal down due to the tires being vinyl. (turns them shiny, gummy & sticky) I would like to have a dull finish...can anyone make any recommendations?
Thanks!!
Old 03-10-2011, 06:45 PM
Helico's Avatar
Helico Helico is offline
Re: Help: vinyl tires & clear
I use a mix of Future and Tamiya flat base. Of course any water-based acrylic flat or semi-gloss will do. I have never tried lacquer on vinyl. Perhaps the solvent turns vinyl gummy?
Old 03-10-2011, 08:43 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
For vinyl tires, you either have to use an acrylic clear, or a lacquer clear. If you use an enamel clear, it will never dry completely.
Ive had good luck w/ Testors Lacqure flat clear when doing tires for my Nascar race car models.
Old 03-10-2011, 09:40 PM
935k3's Avatar
935k3 935k3 is offline
My method works pretty well. I first use a Q-Tip and apply a coat of Future to the sidewall. Then I apply the decal and let dry. I then brush on a coat of Polly Scale clear flat(shown below) and sometimes a second coat. Brushed properly with a good brush shows no brush marks. I think the white decals are a little to clean and bright so I tone them down with some graphite powder(made by sanding a pencil)and applying it with a Q-tip over top of all.
Old 03-11-2011, 07:39 AM
eyckles's Avatar
eyckles eyckles is offline
I use microscale decal film. I brush it on and i works like a charm. Had no problems with so far and the finish is dull.
Lesley
The Following User Says Thank You to eyckles For This Useful Post:
corvettekid_7684 (03-21-2011)
Old 03-14-2011, 02:28 PM
Thanks for the tips!! Now I just need to find some of these items. Local craft store doesn't carry any water based flat clear...
So a lacquer will dry OK over the vinyl? Is Testors dull cote a lacquer?
Old 03-14-2011, 08:52 PM
IPMS24834's Avatar
IPMS24834 IPMS24834 is offline
I believe that both the spray can and the square bottle are lacquers
Modeling Stuff:
Currently offline
Reference Photos:
Old 03-15-2011, 05:43 PM
Rattle Can
http://www.scalehobbyist.com/catagor...60/product.php
Bottle
http://shop.towerhobbies.com/cgi-bin...&P=WR&I=LXHM69
Old 03-17-2011, 02:36 PM
Just to verify, lacquer will cure over the vinyl tires?
Old 03-17-2011, 09:12 PM
Yes, lacquer works just fine on tires.
Not the best picture, but the best I could find in my pic albums. The tires on this car were done w/ Lacquer. Gloss clear the tire, put down any decals you need, and then flat clear the tire, and it looks excellent.
The Following User Says Thank You to Adam Baker For This Useful Post:
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
Any suggestions on how to turn down the INSIDE of a vinyl tire? DSM-Mark Car Modeling 4 06-02-2004 10:36 PM
My clear tail lighs & clears for sale 4thGen4Door '88 - '91 Civic | CRX | Wagon | Shuttlee 21 10-10-2003 02:18 PM
WTB: clear side marker & clear or black bumper lights leslieo Accord/TSX/Accord Hybrid 0 07-12-2003 05:04 AM
