Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 03-10-2011, 02:30 PM
ravx3 ravx3 is offline
95 tracker coolant leaking
My tracker started leaking coolant the other day and overheated.
(1.6l- 16v)
When I got it home and refilled the rad. I noticed I was still gettin heat and couldn't see any leaks anywhere.
I shut the heater off and revved the engine and leaking began.
It seems like it's coming from the top of the back of the head against the firewall somewhere. Dripping down to one of the hoses from the heater core.
Can't see good there because of all the stuff there.
It seems like one of the hoses from the heater core goes up that way.
Does anyone know what is up there and how the hose is connected.?
Appeciate any help.
Old 03-11-2011, 09:23 PM
farmerfelts farmerfelts is offline
Re: 95 tracker coolant leaking
Had something similar on my 96 and it actually was the heater hoses that had finally cracked under the clamps at the firewall and were squirting onto the back of the engine. It was a pig of a job to replace them too.
Old 03-12-2011, 03:54 PM
Thanks for the info.
I was able to move some other lines out of the way and I did see where that hose led to and where it is leaking, you were right about the hose leaking and it does looks like it is going to be a real bear to get at.
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 08:53 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 11:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 05:17 PM
91 caprice leaking coolant leaking coolant Maticlee Caprice 12 08-20-2008 09:31 AM
Small Coolant Leak/Burnt Coolant Smell Through Heater??? Please HELP ASAP! NebulaD Sable 6 04-08-2007 10:50 AM
