Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-10-2011, 12:31 PM
AJ&J AJ&J is offline
AC Pulley to replace AC compressor
I have a 93 Trans Sport with a 3.1. The bearing in it has failed and I don't want to put out the money for a new compressor. I can find a pulley that replaces the compressor for a 3.8, but not the 3.1. There is a pulley listed for a 90-91 for the 3.1. I have owned several of these and for the life of me, I don't remember and difference under the hood from a 90 to a 93 with a 3.1. Does anyone know if this will fit? Does anyone have a solution to bypass the AC compressor?
As always, any input is appreciated.
Old 03-10-2011, 01:08 PM
brcidd's Avatar
brcidd brcidd is offline
Re: AC Pulley to replace AC compressor
A good boneyard, $35-$75 will have what you need.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-11-2011, 09:44 AM
LMP's Avatar
LMP LMP is offline
YOU can simply (EDIT..well..not that simple) reroute a shorter belt avoiding the A/C compressor. I have the specs for the 3.8....will look for the 3.1.........
ahh.OK ACDELCO Part # 6K598 {#88932703} K06 13/16" x 60 3/8" BELT,SERPENTINE w/o A/C
The a/c belt is only 10 inches longer......there is a much greater difference with the 3.8 (104 and 72) ...I'll look if I can find the actual routing....
Explanation: indeeed you need an idler pulley
ACDELCO Part # 38009 {#88909590} GROOVED PULLEY; Thermoplastic V-Ribbed 6 Grooved (76mm x 17mm x 25mm) PULLEY,BELT IDLER w/o A/C
data taken from rockauto.com. I 'm not sure the idler pulley listed is the complete unit or just the replacement pulley/bearing....
...I would seriously consider brcidd suggestion....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
A/C compressor replacement jarl Trans Sport 5 12-12-2010 05:39 PM
Crank pulley replacement fiberglasscivic Avenger 2 07-11-2005 11:28 AM
Idler pulley , ac compressor pully bearings Markgase2000 Grand AM 1 09-11-2004 03:02 PM
Does the engine have to be pulled for pulley replacement? rstaylor Caravan | Voyager 2 02-25-2004 12:56 AM
Just had my tensioner pulley replaced!!@800miles/- 02ci 3 Series 0 02-06-2002 11:00 PM
