Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-10-2011, 09:04 AM
firozhirji firozhirji is offline
Question 2006 LE Hard Shifter
I have a 2006 Camry LE automatic.
It is very hard to shift the car into R or D from P.
I took it to a dealer and they lubricated "everything" and told me all was fine --there was no charge for this.
Still experiencing hard shifting and it is extreamly hard on cold days.
Any ideas what can be wrong? thanks
Old 03-15-2011, 08:29 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 2006 LE Hard Shifter
Three things come to mind:
1) When you took it to the dealer, did they also check the transmission fluid level and condition? Dumb question, yes, but I'm trying to discount the obvious for all.
2) Do you park the vehicle on a hill? If so, the vehicle will roll slightly so that the little parking pawl inside the transmission is put under pressure by gravity (the car wanting to roll downhill) and makes it harder to release it when you shift out of Park. To prevent this, engage the parking brake before you shift into Park. If the P-brake can't hold the car on the hill, then it needs to be adjusted.
3) Are you stepping on the brake before you try to shift out of Park? This is a standard safety feature on all vehicles. If the brake safety switch is faulty, it will not allow you to shift out of Park or make it very difficult.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-17-2011, 12:19 PM
Hope this helps!
Yes transmission fluid is OK. The car was not parked on a hill and I have my foot on the brake.
Since the weather has warmed up from below freezing the shiftinh is much less harder but still stiff.
Hard to Find Parts - Hard to Contact People (Long Post, sorry) 89audiQT Car Modeling 13 02-19-2007 07:48 PM
1996 Sable - Ignition switch Hard to turn to full off & hard to remove key DonNanneman Sable 1 02-13-2007 01:07 PM
