Old 03-07-2011, 07:43 PM
mutewitness616 mutewitness616 is offline
safety switch 87 LeSabre help
I bought a 87 LaSabre and it works fine.. only problem was it wouldnt start so we took it to the mechanic and he said the problem was the neutral safety switch...
so while the guy was installing it he accdently broke a screw that is what is conencted to the gears or transmission something like that..
the circled part is where the screw goes and that is broken..
Old 03-08-2011, 09:55 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: safety switch 87 LeSabre help
That's where the shaft to the transmission that determines whether or not you want the car to go forward or backward goes through. The Trans pan will need to be dropped along with the valve body in order to replace the shaft. This is also the same shaft that the shift lever that the shift cable attaches to. Without that you will not be able to put the transmission in any gear.
Hopefully they can figure out some sort of remedy other than replacing it.
helpful youtube video re: TRS - neutral safety switch northern piper Windstar 1 04-09-2009 12:37 AM
Help! Neutral Safety Switch andreakip Ram Van 1 03-19-2009 03:29 PM
Neutral Safety Switch Help mconover867 Cherokee 7 02-01-2006 06:26 PM
neutral safety switch - help! orderxaos Cherokee 11 04-17-2005 10:47 PM
Help! Neutral Safety Switch moo1716 Cherokee 4 10-18-2004 12:32 PM
