Old 03-07-2011, 05:14 PM
pete44 pete44 is offline
Unhappy Service Engine Soon Light
Hello.
Having issues for awhile with my 1992 C1500 5.7L Chevy pickup. It has had a rough idle and "stumbles" below 1500 rpm (inwhich I shift it to D to get it out of overdrive) I did some meter checks (by Haynes manual) and changed out the TPS and the MAP sensors (which metered bad)...It runs a little better but still has the "stumble" at low rpm's in overdrive. My SES (service engine soon light) comes on for 10 to 12 seconds then goes off for 10 to 12 seconds in a cycling mode. I looked at distributor (under cap) and it is nice and dry. Plug wires are good and seated. I have developed a small oil leak that seemed to happen when my truck started running bad. (Thats what had me check under the distributor cap). I am going to AutoZone in the morning to see if they can pull some codes..Any suggestions?
Thanks,Pete
Old 03-08-2011, 10:58 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Service Engine Soon Light
Check for vacuum leaks. Grab a can of carb cleaner and spray around the vacuum lines, TBI base, and breather hoses while the engine is idling. If it stumbles, you found a leak.
Also check the thermostatic air diverter in the air cleaner snorkel. If it's stuck shut it draws in hotter air from the exhaust manifold, which is less dense, creating a rich mixture that the ECM isn't expecting.
Finally, have the ECM scanned for codes anyways. Even if the SES light is off it will store past codes in memory. You can jumper between two OBD terminals to extract the codes...check a repair manual for the correct ones. There's also a sequence to reset the codes, too, to be sure the codes are recent.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-09-2011, 10:01 AM
OK, I went ahead and carried it in to have codes checked at a shop.(Since a '92 is too old to have checked at Advanced Auto or AutoZone)..It came back with:
Code 22 (TPS too low)
Code 32 (EGR System Problem)
I have already replaced the TPS . So they could have read a history alarm. I HAVE NOT replaced the EGR. I did the EGR test (plugging vacuum line to it) and it made no change to rough idle. Mechanic at shop said it would not be that anyway. This leads to yet another possibility..The ECM???...Haynes said it is under dash but mentions nothing about testing it...Has a chip inside so I am assuming you can replace chip or whole ECM.By Haynes code chart it mentions ECM wiring or replace for these issues...Any more thoughts?
Thanks, Pete
Old 03-09-2011, 11:38 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thanks, Pete
Proper testing.
Always clear codes and see what returns.
Also what transmission you have?
On code 32 if it returns.
And you have a V8 with no 4L80 transmission.
Key on engine off ground pin A to pin B on diagnostic connector and see if egr solenoids activates to allow vacuum threw it to egr valve and egr valve opens and holds vacuum.
Also with egr valve open and engine running it should give a rough idle with egr valve open.
To get egr open you have to apply vacuum to it or reach in it and open by hand.
Run these test and let us know what it does and what codes returns after code clear.
MT
Old 03-09-2011, 02:21 PM
Thanks... I tried before to move the EGR by hand and it was nill to none by movement. (read somewhere that it should be pretty easy to move)..The tranny I have is the 700r4...I am still suspecting the EGR but the ECM is lurking in the background to be the culprit.
Pete
Old 03-09-2011, 03:42 PM
MT-2500's Avatar
AF - Advisor
Pete
Run the proper test before throwing ECM at it.
Have you cleared codes and checked for what comes back.
Have you done the egr valve solenoid test?
Most egr valves should open by hand.
If not put a good vacuum on it.
When it opens it should almost stall engine or cut idle way down.
MT
Old 03-09-2011, 07:51 PM
j cAT j cAT is offline
I am not saying this is your problem ........
I have alot of experience with these EGR valves and intake EGR passage ways that have issues.
to say a bad or improperly operating EGR cannot cause your problem is not correct..................
the valves can fail many ways , sometimes the intake causes this also.
stumble on acceleration could be a weak EGR spring as just one example .
EGR is calibrated to produce a set amount of exhaust gas into the combustion chamber . too much you get a stumble [not enough oxygen].
Old 03-10-2011, 02:53 PM
Thanks for the replies....The shop I took it to cleared the codes only for the "service engine" to come back...They basically hurried me out of there (5 minutes) but it was free. They told me to come back in a week to re-read the codes again.. I went to Auto Zone and they have an OBD1 analyzer. Not much to it ($35)..Don't even know if it would even clear my codes. I have plugged the EGR vacuum line (going to EGR) and no change in engine idle. (still rough)..I have a vacuum tester and will perform placing vacuum on EGR. I saw an online site that has ECM ($100 and up) that I bookmarked. EGR I looked at around half that price...If the ECM was bad I assuming it would throw a code ?
Thanks, Pete
Old 03-10-2011, 03:12 PM
MT-2500's Avatar
AF - Advisor
Thanks, Pete
on bad ECM throwing code.
A 2 bit paper clip will show codes.
Just jumper pin A and B on the diagnoist connector and read flashes on check engine light.
Battery cable disconnect will clear codes.
You need to put vacumn on EGR valve to test it.
Pluging EGR valve does not tell you aything but may set a code.
Do the proper testing before throwing parts at it.
Bad ECM does not usually throw a code saying it is bad.
MT
Old 03-10-2011, 05:52 PM
Thanks, Pete
take the EGR off the engine . make a plate to block off the ports. see if the engine idles better.
Old 03-11-2011, 05:08 AM
MT-2500's Avatar
AF - Advisor
To add to Jcats pull EGR valve.
Good time to have a good look at the EGR valve.
Check for being stuck open or carbon under plunger keeping in from closing.
Alos a put lips over plunger hole and give it the old nasty suck on it test to see if it is sealing closed.
If you do not have a cover plate for egr valve holes put masking tape over suction hole and leave exhaust hole open.
Start engine and see if idle is better.
Let us know how it goes.
MT
Old 03-11-2011, 02:20 PM
Crazy question...How do you know which one is the exhaust hole and which one is vacuum hole?
Old 03-11-2011, 03:06 PM
MT-2500's Avatar
AF - Advisor
Very easy to tell when you start engine.
Just Fire it up.
The vacuum hole will have engine vacuum.
And engine will run like crap untill you plug it.
And exhaust hole will spit out ehaust.
Plug vacuum hole and see fhow it runs.
Let us know how it does and be suer to check EGR valve when it is off.
MT
Old 03-11-2011, 07:05 PM
that is very funny !
Old 03-18-2011, 07:14 AM
Update:
I checked my EGR and my EGR Solenoid by applying vacuum.Both OK.EGR with applied vacuum made engine idle worse and EGR solenoid held vacuum fine (no leaks) Still suspecting ECM..Any more thoughts? I am going to try and run by shop today to check codes again..They cleared them over a week ago..
Thanks again, Pete
Service engine soon light. Engine codes RK4332 Grand Marquis 2 09-20-2006 03:55 PM
Steering wheel locked up, Service Engine Soon light, Flickering head lights AnimalDrMarshall Aurora 2 06-01-2006 10:49 AM
89 camaro engine trouble...service engine soon light Cbballplaya Camaro Discussions 17 10-24-2004 04:02 PM
service engine soon light IDHITIT S-10 7 03-31-2004 06:05 PM
Service Engine Soon Light and Service Light bowmanslandscaping SC/SL/SW 3 05-03-2003 02:43 PM
