Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Technical: How To... - FAQs
Technical: How To... - FAQs All How To's and Frequently Asked Questions.
Old 03-06-2011, 07:29 PM
eric_454's Avatar
eric_454 eric_454 is offline
MSD Opti-Spark Quick Fix
The other day I got a code 36 for the High-Resolution pulses in the distributor. Here's how it went. Tore down the 94 LT1 Z28 to pull the Opti off. Drain water, belt, power steering, water pump, crank pulley. Loads of fun.
http://www.flickr.com/photos/58835151@N02/5504010703/
Little dirty but looked ok till I tore it down. Bearing was out, I think washed out by invading engine oil from leaking intake and distributor seals, among others. Did intake the next morning. Was easy.
Here's some idea how to do this. Saved hundreds of $$$ over buying a new Opti.
Trip to the local IBT
Put the bearing in.
The Drive Hub.
The Reluctor.
The Shielding.
And the Rotor.
And there you have it! Simple fix for code 36.
I figure the bearing being a little loose (REAL bad) had the reluctor and pick-up out of phase. Tapped in a new set of the three seals in the timing cover while I was in there. Job was easily done on a set of ramps.
Runs for now but "Might Shut Down" at any time. Good Luck!
Here's the link to pics. Can't seem to get them up.
'83 Pontiac Bonneville
361 SBC .150 domes
3.500" Sprint car crank
Comp 260 H
3.73:1 behind 700 R4
Jensen tape deck & 6X9's
Need an Opti-spark swap how-to FormulaForce F-Body Problem Diagnosis 2 09-19-2007 08:53 PM
vibration after opti-spark install tob3soon Camaro Discussions 4 08-07-2006 12:30 PM
opti spark replacement, do you know how to? doodad Camaro Discussions 3 04-11-2006 09:47 AM
Opti Spark! 94 Z28 Sonic5395 Camaro Discussions 1 12-25-2005 12:23 PM
I love Opti-Spark Lotus49 Camaro Discussions 7 12-08-2004 09:04 PM
