Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-06-2011, 04:23 PM
tennykimble tennykimble is offline
88 integra coolant temp sensor???
i have an 88 acura interga, -- inline 4 cyl >< dual overhead cam-- that has VERY hard starting ( very long crank time ) i have been over (and over) (and over) this thing trying to find my problem but no dice!
cam timing is good. ( all the marks line up)
ing timimng is good,
(i checked it after i got it to start and idle on a 45 degree day)
good spark,
good compression 180 +- 30 ( each cyl )
fuel pressure is good ( around 40 psi @ cranking)
i have put ( new ) in car
plugs, wires, coil, fuel filter, ign control module.
it seems like the colder it gets the harder it is to start ( & keep running )
the only thing i can think of is the timing advance / retard unit is not working??? the book says that is compouter controlled ?? but i am thinking maybe its the coolant temp sensor send a bad ( or non exsistant ) signal.
so my next question is WHERE IS THE COOLANT TEMP SENSOR on this thing??? i cant find it!? any info is appreciated THANKS!!
94 s-10 blazer 4.3 w temp guage! exalteduser Problem Diagnosis 8 08-26-2009 04:54 PM
01 Silverado Coolant Temp Sensor wiring okieguy Silverado 1 08-10-2009 07:39 PM
Coolant Temp Sensor or ECP sensor? myjeepsux420 SC/SL/SW 2 04-19-2005 01:57 PM
correct voltage/testing MAF sensor, 02, Coolant Temp sensor anticowboyism 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 08-02-2004 01:23 PM
88 Integra Coolant temp Sensor Stavesacre Engineering/ Technical 0 01-07-2004 06:24 PM
