Go Back   Automotive Forums Car Chat > Daewoo > Lanos | Kalos
Old 03-06-2011, 04:01 PM
Blackjack2 Blackjack2 is offline
Can i just unbend my radiator and condenser?
It was a rainy day and i slid into the back of a mustang. My bumper went under the mustang and i ended up smashing my hood, condenser and radiator in. I was wondering what the condenser was for, if i could just unbend it.
Can i do the same for my radiator? I was all so wondering.... I was going like 5mph when i hit the guy, could any thing else be wrong? All i can see is a bent radiator,hood and condenser.
Old 09-19-2013, 06:36 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Can i just unbend my radiator and condenser?
The condensor is the heat exchanger for the air conditioning system. You cannot just unbend it and expect it to work. It will likely crack if you bend it, although there's a good chance it already has a hole in it. Same goes for the cooling system radiator.
As for your question on if there's anything else you need - it sounds like you need new tires.
-Rod
Old 11-07-2014, 01:32 AM
LeoTheLion89 LeoTheLion89 is offline
Send a message via ICQ to LeoTheLion89 Send a message via AIM to LeoTheLion89 Send a message via MSN to LeoTheLion89 Send a message via Yahoo to LeoTheLion89 Send a message via Skype™ to LeoTheLion89
seems like alot of damage for a 5MPH hit.... The A/C in my Lanos never worked anyway. If that is your case i would just buy a new Radiator at AutoZone (they cost about 180 bucks on back order) and just remove the radiator and condenser and just put a radiator back in and forget the condenser.
Can 95 Lumina A/C Condenser be flushed? blk95lumina Lumina 1 09-16-2009 09:33 PM
A/C compressor and condenser... Chad of Metal SC/SL/SW 2 05-27-2009 07:43 PM
Oil in the radiator and in the radiator fluid reserve tank douaty Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 08-24-2008 10:48 AM
Radiator and condenser silverado122775 SC/SL/SW 4 08-30-2007 01:01 PM
