How to fix large dent
Hey guys,
I was turning past a post and I turned too tight and clipped the side of my C/K pickup, right by the fuel door. There is a large dent (no paint chip or scraping thankfully) along the panel from the fuel door up to the wheel well. I'm wondering what the best way to fix this dent is? Should I just hammer it out from the inside? Hair dryer and air duster? Thanks, Alex |
Re: How to fix large dent
If it is through the body line, the crease down the side of the truck, it wont come out. Otherwise I have had luck by taking a suction cup, like for holding up windows, and try to pull it out. You can try hitting it from the backside but use something with a big surface area or even your hand. If it takes alot of force it prob wont pop back out. Try to post a pic.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
You might also consider a professional Scratchless dent removal.
Thanks for the replies guys. Here are the pics. This one's been really upsetting me; I just finished bringing this baby back to life last week
![]() What do you think? |
There is a franchise called (if I recall correctly) Dent Doctor, who may have someone in your area. . They should be able to improve it a lot. Chances are, the dent will still be slightly visible, but its much cheaper than traditional body shop methods. I suggest not to attempt fixing it yourself, The metal is slightly creased, so unless you know what you are doing, you can easily make the damage worse. Try here for more info: http://doctordoording.com/pricing.html |
Thanks for the advice! Hate to say it but I don't really think the truck is worth enough to have it done professionally. If I was to do it myself, would using a suction cup give the best results?
Thanks |
Yea, find the biggest one you can and give it a go. From what i have done with mine it should def look better but the top and the bottom will need body work to fix.
Just do what everybody else with body issues do, buy a bunch of bullet hole stickers.
The area that started to crease is going to be a problem. You can get most of the dent pulled by suction cup and/or working behind the panel, but the uppermost crease will require a little more than that. I've had reasonable success with soft tools, like a clean (i.e., brand new) medium durometer rubber mallet and a soft wood block behind the panel as a dolly. The results are never perfect, but it's fairly impressive for a quick massaging out of larger dents. Short of working it with a dolly, spot weld puller, and grind/prime/paint, that's about as good as it will get.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
I'd call a local body shop and find out who they use for paintless dent repair. The quote for my alero (beater) to remove all the door dings and things along the whole side was 300.00 which isn't too bad all things considered.
Like stated, where it started to crease a little is going to be a problem.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
