Old 03-06-2011, 12:38 PM
pryornfld pryornfld is offline
Intermittent Oil Light 2005 Grand Caravan
Hey,
The oil light come intermittently. The oil level is fine, oil and filter change about a month agbe? Noticed that it happens on extermely cold days after the van has been sitting overnight.Any ideas on what it could be and what I should be looking for?
Tks
Old 03-06-2011, 07:24 PM
N8ECH N8ECH is offline
Re: Intermittent Oil Light 2005 Grand Caravan
Most likely, the oil sending unit is bad. It screws into the block near the oil filter.
My 04 Durango's sender failed the same way. First start of the day when cold, light would stay on. If you shut it off, the restart the light would go out.
Not expensive, and not hard to change.
Don
Flame Red 2004 Hemi Durango SLT 4x4
w 3.55 gears.
Old 03-06-2011, 10:23 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Yup, flip a coin and chose between connecting a direct pressure gauge to verify the actual pressure or just change the sender.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 03-10-2011, 04:01 PM
Seems that if the light goes on, if I turn off the van then back on, the light goes off.This tell me that it is probably the sending unit not the pump.Any comments on this?
Old 03-10-2011, 10:56 PM
b1lk1 b1lk1 is offline
Without installing a known good mechanical gauge to test the true oil pressure any other thoughts or opinions are pure speculation and not going to give any real definitive answer. You really should temporarily install a mechanical gauge to get the correct answer.
Old 03-12-2011, 07:25 AM
What pressure should I see when I connect the pressure guage?
Old 03-12-2011, 08:36 AM
I don't know the exact specs, but I would worry if I saw it drop below 20PSI at any time. I'd have to guess that 30+ would be the specs.
Old 03-12-2011, 04:45 PM
joeslip joeslip is offline
the oil lite comes on when the oil pressure drops below 7psi.
Old 03-12-2011, 05:27 PM
The oil light comes on when the computer thinks the pressure is below that. That does not mean quantifiably that it is indeed that low. You cannot trust dashboard gauges and lighs to be anything more than a warning, never take them as they are not for diagnosing purposes.
Old 03-24-2011, 05:42 PM
Changed the oil sending unit as the pressure seems to be fine.So far, the light hasn't come back on.Will post back if it does.Thanks to all!!
2005 Grand Caravan Oil Leak ontheedge02 Caravan | Voyager 3 03-14-2009 01:30 PM
2005 Grand Caravan Airbag light is on wensull22 Caravan | Voyager 3 01-22-2009 07:14 PM
2005 grand caravan engine light 36000 miles JakeJ Caravan | Voyager 1 06-28-2006 09:13 PM
2005 Grand Caravan Center Console gmac3030 Caravan | Voyager 0 03-08-2005 10:41 AM
