Old 01-14-2009, 10:33 AM
wensull22 wensull22 is offline
Red face 2005 Grand Caravan Airbag light is on
I assume it's the airbag light on my dash panel has been on for over a year. I haven't had any work done on it so I don't know what is going on. Before it went on, my ABS light would come on and off and the airbag light stayed constantly on. I failed inspection because of it! What does the light mean and can I fix it myself? Please help!!
Old 01-14-2009, 04:04 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2005 Grand Caravan Airbag light is on
The airbag light means the system has been deactivated due to a failure. There is a service bulleting (# 08-020-07) on your van for cracked airbag sensors. You must have an R in the 11th position of the VIN # for it to apply. Not sure if Chrysler or you pays for it if the van is out of warranty. Once repaired you get a lifetime warranty on it. Check with your dealer.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-18-2009, 05:55 PM
turkeyman66720's Avatar
turkeyman66720 turkeyman66720 is offline
Send a message via MSN to turkeyman66720
also could be the clock spring had exact same problem on mine abs airbag and intermintit wipers replaced clock spring its behing the stering wheel if the other is not you problem thismight be,..
1987 chevorlet silverrodo 5.7 Liter Tbi
1997 dodge grand caravan sport 3.3 Liter
1991 oldsmobile eighty eight 3.8 Liter 4dr
Old 01-22-2009, 07:14 PM
DirtRaceFan79 DirtRaceFan79 is offline
even if the tsb mentioned does not apply to this vehicle, check the front impact sensor connectors. I've had to change many of the connectors due to heavy green corrosion inside the connector. The best thing to do is find someone who can scan for what code is in the system. They are also well known for poor connections at the passenger airbag.
