Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-04-2011, 04:37 PM
Bretthughes1970 Bretthughes1970 is offline
Dead Batteries
I am having to replace battery every 24 hours. The alternator has been checked and is operating correctly. The problem started with sparks flying while I had to jump start. I didn't reverse the jumper cables. Any possible suggestions?
Old 03-04-2011, 10:15 PM
old_master's Avatar
Advisor/Moderator
Re: Dead Batteries
With a fully charged battery and the engine at 1,500 RPM, check voltage at the battery terminals and post your results.
You have to know how it works,
to figure out why it doesn't.
Old 03-10-2011, 06:05 PM
lectraplayer lectraplayer is offline
Re: Dead Batteries
you having to chrge or replace the battery? If it's just going dead, check for something shorted or staying on while the truck is parked.
Old 04-11-2011, 07:46 PM
KnobbyTires KnobbyTires is offline
Re: Dead Batteries
Good Batteries Don't Die Young. Disconnect the battery positive post and measure it's resistance to ground. Shake the cable, and follow it all the way down to the starter, it could have worn through. Something is definitely shorted to ground.
01 Expedition - Battery Dead in 45 Minutes djtroz Expedition 6 02-04-2011 01:53 PM
Lost Key AND Dead Battery! db99 Town Car 7 06-09-2010 10:25 PM
95 Jeep Grand Cherokee Radio Fuse Keeps Blowing - Dead Battery ajcool Grand Cherokee | Grand Cherokee SRT8 1 04-25-2010 10:30 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
dead battery...dead keyless remote??? xerorex SC/SL/SW 1 11-13-2004 11:40 PM
