Old 03-04-2011, 10:31 AM
99kylec 99kylec is offline
Code P0452
Just started when i was on the high way..The check engine light was flashing also had codes P0301, P0327..I have smelled fuel Once or twice in the last few days .. I have replaced the fuel pressure regulator ..could it have gone bad? I put in a new fuel pump 4 weeks ago and filter..PCM 2.0 from ZZP..any suggestions what to check? thanks AF
Old 03-04-2011, 03:03 PM
danielsatur danielsatur is offline
Re: Code P0452
Trouble with EVAP pressure sensor error!
Old 03-04-2011, 04:40 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Code P0452
P0452 = Fuel Tank Pressure Sensor Circuit Low Voltage
P0327 = Knock Sensor Circuit Low Voltage
P0301 = Cylinder number 1 Missfire
Lets worry about the most important code first. P0301. If you are smelling gas and have a flashing SES with P0301, you could burn your CAT up if you continue to drive.
I assume you have a GTP since you have some MOD's. What made you decide to go with a ZZP 2.0 PCM rather than just a 1.0? What other mods do you have? Smaller pulley?
You could try to reseat your PCM connector. Check for bent pins and corrosion.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
The Following User Says Thank You to tblake For This Useful Post:
99kylec (03-05-2011)
Old 03-05-2011, 04:56 AM
Re: Code P0452
sorry it is a 1.0 pcm but the SES will go away if i dont drive on the highway ..its only when i got to pass someone will the SES flash ..iv had poor boost it will max out then go back to a few bars then max out? i dont drive WOT very often just when i have too.
Old 03-05-2011, 07:31 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Code P0452
what octane fuel are you running? I understand with today's gas prices premium hurts, but running a modded GTP on 87 octane is a big NO-NO!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-05-2011, 07:43 AM
Re: Code P0452
I run 91octane and i run a fuel cleaner every 4 tanks of fuel...
Old 03-05-2011, 07:44 AM
richtazz's Avatar
Re: Code P0452
Do you have the other supporting mods for the PCM you have?
Old 03-05-2011, 06:51 PM
tblake's Avatar
In God We Trust
Re: Code P0452
First figure out why its missfiring on number one. It only does this on accelleration? May want to check compression.
Old 03-07-2011, 11:47 AM
Re: Code P0452
Found spark plug wire bad ..rebooted pcm and everything works great..thanks all
Old 03-08-2011, 11:20 AM
Young Chuck D's Avatar
Young Chuck D Young Chuck D is offline
Send a message via AIM to Young Chuck D
Re: Code P0452
simplest solution is usually right.
I would have started at the plugs and wires, then coils, etc..
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles]
Gone but not forgotten:
1995 Pontiac Grand Prix GTP[sold, 128k miles]
1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles]
1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles]
1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems]
1990 Hyundai Excel GL [died, 220k miles, died]
P0452 jibberesh S-10 3 06-28-2012 07:54 PM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
99 GP GT Stalls - Code P0452 eippermx Grand Prix 2 06-02-2007 09:30 AM
Fixing a trouble code P0452 bsilverado00 Silverado 4 04-09-2007 10:02 PM
Code P0452 Set Mork Silverado 5 12-10-2004 03:23 PM
