Old 09-29-2009, 06:35 PM
jibberesh jibberesh is offline
P0452
I spoke with some folks at a shop and I couldn't get a specific answer. I have a 2000 chevy s-10 and it threw po452. Gradually over a period of a week it got harder and harder to start. Finally it died. I was having a strong gas smell and was told that the evap control valve would be the culprit. Where is it exactly? I know the sensor is on top of the tank, and the regulating unit is back by the tank to. The only schematic that I can find shows the control valve somewhere near the throttle body. Can some one tell me more specifics? Thanks!
Old 10-06-2009, 12:32 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: P0452
Code 452 is for fuel tank pressure sensor problem.
But should not cause no start.
Any other codes?
Check fuel pressure and look for the gas smell.
What engine?
MT
Old 06-27-2012, 07:20 AM
vizial vizial is offline
Re: P0452
u have any luck with ur problem yet?... is yours a 4 banger/ automatic?....ive got one here with the same problem?...scanner says everything is within specs and working?..452 keeps coming back. gotta be purge sol., vent sol.,pressure sensor or the plumbing between them all? every thing "looks" good..?...
Old 06-28-2012, 07:54 PM
j cAT j cAT is offline
Re: P0452
what can happen is fulling up the fuel tank too much and then parking in the heat of day fuel will go to the cannister. this then gets plugged up. the control valve also gets plugged up with charcoal from cannister. follow the vent lines and find the cannister. check that the line to tank is not blocked. blow thru cannister to see if its blocked.
make sure the cap is the correct one. sometimes these caps mess up and cause too much vacuum. tank pressure goes into the cannister to be absorbed. fuel vapors means that this needs checking and testing.
best have a diagram so that you can follow this correctly.
Tags
diagnostic , evap , p0452
