Old 03-04-2011, 01:08 AM
91BoOstedCRxsI 91BoOstedCRxsI is offline
How much power can i handle!
So ive got a b16a that i am currently building. Cp pistons, Crower Rods, Supertech Valve springs and titanium retainers. arp main head bols and studs Rc750cc injectors ported and polished head. walbrough 255lph fuel pump. stock sleeved engine running 9:1 comp.. with block guard. The question is, about how much power could i expect to make on that setup??? anything helps thanks fellas.
Old 03-04-2011, 06:11 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: How much power can i handle!
Is there a turbo coming with it?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-07-2011, 10:51 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
That’s a very open-ended question as many turbo set-ups can handle varying amounts of power. I believe you should have a set goal in mind and then ask “can my engine handle ____hp.” Ofcouse having your car tuned on E85 will increase the amount of power you can produce but you’d need bigger injectors. Your only limiting factor that I can see is the stock sleeves. Did you have a turbo and/or hp number in mind?
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
how much power can the stock rearend handle jason-1995fbody Suspension and Drivetrain 4 01-29-2010 02:07 AM
How much Power can a Stock Internal D15B2 Handle? flip888 '88 - '91 Civic | CRX | Wagon | Shuttlee 11 10-13-2007 05:05 PM
700R4 - How much power can it handle? Johnnyfiveoh Jimmy 1 09-01-2003 10:39 PM
Turbo CRVTEC - how much power can gearbox handle? trancier '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 03-15-2003 04:30 PM
How much power can standard mod bring you? pche059 Engine 6 09-27-2001 11:43 PM
