Old 03-03-2011, 01:09 PM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
p0496 problem
My 04 cavalier (2.2 ecotec) has a code p0496. I know this is something to do with the evap canister and some kind of valve, but what exactly is going on here, and what does this purge system do? Any suggestions on how I should approach the elimination of this issue are greatly appreciated.
Old 03-03-2011, 01:13 PM
Re: p0496 problem
I must note that i cleared the computer about a week and a half ago and the cel didn't come on until about three day ago. I cleared it again and it hasn't come on again yet, but I suspect that it will. I have noticed that it turns on when i first start the car and is idling for a couple of seconds before i set off for my destination.
Old 03-03-2011, 07:01 PM
danielsatur danielsatur is offline
Re: p0496 problem
Check the fuse/relay for both the Purge and vent solenoids for the EVAP system.
The Vent control solenoid is the most probable cause, being exposed to more elements.
The Following User Says Thank You to danielsatur For This Useful Post:
razr_88 (03-08-2011)
Old 03-08-2011, 05:56 PM
Re: p0496 problem
ok thank you. I just went out and tried to find the fuse/relay and I didn't see them at all i checked under the hood and behind the panel on the drivers side is there another location of fuses and relays?
Old 03-08-2011, 06:17 PM
Re: p0496 problem
also i can't find the location of the canister itself. in my last two cars it was in the engine bay
Old 03-08-2011, 06:22 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: p0496 problem
When you clear the code, the PCM needs to go through drive cycles to test all its monitoring points before it determines normal engine operation or a fault. If the monitors pass, then no code, if a monitor fails, then a code is flagged as a pending code. The second time that monitor is failed a MIL is generated to notify you of something wrong.
Try these pin point test procedures and see if you can find a solution to your issue. If you could right click and "save as", I'm going to be pulling the link down in a few days to save bandwidth on my server.
http://baystategearheads.com/stuff/cavy.pdf
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
The Following User Says Thank You to HiFlow5 0 For This Useful Post:
Old 03-08-2011, 06:24 PM
Re: p0496 problem
ill bet its by the gas tank or something... what a pain
Old 03-08-2011, 06:27 PM
HiFlow5 0's Avatar
Stanger
Re: p0496 problem
I'm not finding the exact location in the shop manual, but its either in the engine compartment bolted to the frame or near the gas tank. It's used to vent vapor from the gas tank and recycle back into the engine, so you might be able to follow the vent tube from the gas tank to its location.
-2013 Ford Flex
-1999 Ford F150
Old 03-08-2011, 06:36 PM
Re: p0496 problem
ok i'll put it up on jacks and see what i can say
Old 03-08-2011, 07:08 PM
viggy58 viggy58 is offline
Re: p0496 problem
pretty sure the evap can is in the passenger side fender. there is a hard plastic line running from the intake to it.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 03-08-2011, 07:49 PM
Re: p0496 problem
ok so i have it up now and i found a square box between the trunk well, and the gas tank that i believe is the canister. i followed the larger hose and i found this box (it is the one with the sloped bottom)
http://compare.ebay.com/like/1405182...=263602_304662
is this the part that is having the problems?
hmmm i'm doing a bit of research here and i found this part on the autozone website
http://i.ebayimg.com/05/!CB3doQwB2k~$(KGrHqQOKnMEz4BNvjL9BNJPoocHHQ~~_1.JP G?set_id=8800005007
i'll take quick look and see if i can find this one as well
thoughts?
Old 03-08-2011, 08:10 PM
HiFlow5 0's Avatar
Stanger
That's eBay link is the canister purge solenoid, which controls where the vapor is sent, either to the motor or though the canister.
Sent from my DROIDX using Tapatalk
-2013 Ford Flex
-1999 Ford F150
Old 03-08-2011, 08:13 PM
Re: p0496 problem
ok so update... i took the vent solenoid out and took it apart. and found that it is completely filled with spider eggs so i cleaned them out and i will see what happens when i reinstall the old one
Old 03-13-2011, 05:54 PM
Re: p0496 problem
check engine light came back on today... I have the car in the shop for oil change so i'll tinker around a bit. how many ohms should the vent solenoid, and the purge solenoid be at?
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 11:35 AM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 06:44 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 09:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 01:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 08:38 AM
