Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 03-03-2011, 08:37 AM
mario4420 mario4420 is offline
95 Riviera engine noise
I have a 95 riviera 3.8 sc with 67,000 miles, recently I was driving and heard what I thought was a rattle or noise. You hear it when it starts, shuts off, idling when in gear, but stops or is very faint when you give it gas in gear or not. Pulleys are all good except the crank. It makes a half turn in each direction freely, then stops with the belts off. Car runs and drives great, no loss of performance, just this noise. I have a parts motor and the crank does not do that,what do I need to replace?
Old 03-03-2011, 08:44 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 95 Riviera engine noise
Your harmonic balancer is shot...rubber has torn loose between pulley and hub- classic symptoms are a knocking noise on start-up and shut-down- just as you describe. You have diagnosed correctly, now change it out- takes a puller on later model engines, as is yours. Not a bad job. In fact you can practice, using your donor engine first.
Hardest thing is breaking the crankshaft bolt loose- I have used a breakerbar mounted against the frame rail and used the car's starter to break it loose. Works even when an impact gun won't.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
mario4420 (03-07-2011)
Old 03-07-2011, 07:59 AM
Thanks for the advice sure did fix it. Hardest part was replacing the seal, getting it to go in straight without damaging. But it worked only costing $25. 22 for the seal and 3 for the bolts for the puller. Thank you again and hope you can answer any problems I have in the future, hopefully none.
2005 Escape LTD - Engine Noise charettk Escape | Maverick | Escape Hybrid 8 11-05-2010 09:24 AM
'81 Deville 368 engine noise 83mb380sl Deville 2 10-17-2010 06:09 PM
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 09:03 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
